CPU running overly hot.
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi guys i have a CPU Intel i5 2400 @ 3.1oGhz which is currently running at 91oC which too me would be overly hot. the pc its in has 8GB ram so its not like the CPU is taking a massive load as it can be like this 10 minutes after startup with nothing running and CPU usage only at like 0.2% if taking updates etc. its got Arctic MX-4 thermal compound and an Antec KUHLER H2O 650 Water Cooling Kit, what can i do to get the temperature down guys ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: CPU running overly hot.
    Have you made sure that the water cooler is working ie the pump is running alot have issues with the pumps failing. I have the exact same cpu it runs fine with a cheap arctic air cooler even when fully maxed out never gets above 60.
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      its a brand new cooler though would that matter, i fitted myself, im just assuming the water is already in it as there is no way it can open.
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        was looking at this and it says all the fans are running at 0% but the fans are running, why is this ?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          I would advise you don't run it long at all with that and check the temps in the bios as speed fan might be messing something up some where.
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            i checked bios and change it from energy saving to performance but still no change, the temps im getting on speedfan are around the same as bios.
              • 30977
              your fans are 0% because you dont have any with a tacho.
              is your radiator getting hot?
              can you feel the pump running?
                Is this one of those Intel heatsink pogo-pin designs that I've learned to hate? You have to make sure all four clips are in right. They're a pain.
                You have to clamp the heatsink on properly or it will not make good contact and will not have a low enough thermal impedance. The processor will be in low power thermal mode because it is overheating so performance will be considerably reduced.
                  • 30977
                  ah.. this:
                  http://www.antec.com/product.php?id=706539&pid=102
                  is the fan spinning?
                    • 30977
                    did you connect the fan to the socket on the cpu-plate? and the plate to the cpu-fan connector on the motherboard?
                    from what i see in the manual, the mobo should detect the fan speed.
                    and you MUST disable automatic fan speed settings in the bios and run the fan 100% because the cooler has it's own controller.
                    your screenshot looks like you didnt.
                    • Mikeyboy2007
                      • Mar 2013
                      • 745
                      • Scotland
                      Originally posted by stj
                      fan is spinning yes. and to your other comment i will double check, i think i connected fan to CPU fan connection on motherboard.
                      • Mikeyboy2007
                        • Mar 2013
                        • 745
                        • Scotland
                        not sure what you mean Tom but motherboard is Asus P8P67 LE.
                          • 30977
                          if you did then the pump is probably not running.
                          • Mikeyboy2007
                            • Mar 2013
                            • 745
                            • Scotland
                            how do y ou get the pump running if i did.. as this is a brand new cooler, from what ive read online a few people say the cooler should make a noise when it first starts up but this one didnt.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Does sound like a defective cooler you should here the buzz off the pump if its running if not send it back, stick with air cooling its the most reliable in my oppinion.
                              • Mikeyboy2007
                                • Mar 2013
                                • 745
                                • Scotland
                                ok now im realy confused, went into advanced settings in bios and it says the mobo and cpu are running at 29oC and 84oF
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  You are running speedfan 4.38 (6 years old). Speedfan is up to 4.51 now. I suggest you upgrade and see what the new version reports as the old one could have a bug in it?
                                  --- begin sig file ---
                                  --- end sig file ---
                                  • Mikeyboy2007
                                    • Mar 2013
                                    • 745
                                    • Scotland
                                    updated, still pretty high.
                                    • rhomanski
                                      nowhere man
                                      • 5157
                                      • U S of A
                                      According to that your 12 volt line is sitting at 6 volts. How new is the power supply?
                                      sigpicThe Sky Is Falling
                                      • Mikeyboy2007
                                        • Mar 2013
                                        • 745
                                        • Scotland
                                        its been used for around 6 months, its a Corsair GS600
                                          MSI Trident 3 Arctic 9SI-618EU Trident 3 Arctic i7-9700F Specification for Upgrade or Repair
                                          This specification for the MSI Trident 3 Arctic 9SI-618EU can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic 9SI-618EU boardview and Trident 3 Arctic 9SI-618EU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:28 PM
                                          20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                          by sam_sam_sam
                                          I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                          At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                          Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                          04-09-2023, 08:04 PM
                                          MSI Trident 3 Arctic VR7RC-281 Trident i5-7400 Specification for Upgrade or Repair
                                          This specification for the MSI Trident 3 Arctic VR7RC-281 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic VR7RC-281 boardview and Trident 3 Arctic VR7RC-281 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          MSI Trident 3 Arctic 8RB-092UK Trident i5-8400 Specification for Upgrade or Repair
                                          This specification for the MSI Trident 3 Arctic 8RB-092UK can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Trident 3 Arctic 8RB-092UK boardview and Trident 3 Arctic 8RB-092UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        • edugimeno
                                          Stagg sms12p audio amp has water damage
                                          by edugimeno
                                          Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                                          I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                                          There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                                          There is only one signal wire connecting the first boards...
                                          05-24-2025, 06:00 AM
