abit VP6 water cooling
  • sh1ftshape
    • Jan 2005
    i was wondering if anybody have water cooling for their abit VP6? if so can you share pictures, what product you used, how much it costed, etc. etc.
    and also any other cooling product you used including fan/heat sink and wha t case do you use
    thanks in advance if anybody replies :|
  • bushytails
    Moderator
    • Dec 2004
    • 217
    you'd probably get both more and better answers by asking in an overclocking forum, not a bad capacitor replacement forum.
    --Randy
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      while i would like to encourage participation in this extremely busy :o part of the forums, Bushytails is right and you should also post at :
      http://www.abxzone.com/forums/index.php
      • stretch0069
        Screwed Up Super Moderator
        • Oct 2003
        • 2658
        • oooo ess aaaaaaaaa
        not to add to the confusion (which I have an uncanny ability to do ) but I'm not sure you could OC a VP6 to the point where water cooling would be an option. Might just be me, but it seems kinda silly. Take the money you would spend on water cooling and buy a new board. A brand new P4 3GHz CPU, Abit Max 3 something or other (Jimmy is meesing with my memory ) and a Gig of Cosair was only like $500.
        Just me, but now I have that P4 and two VP6s.
        Mikee likes big things.....
        No smart-a$$ remarks there TC.
        "Its all about the boom....."
        Guns kill people like spoons made Rosie O'Donnell fat.
        We now return you to your regularly scheduled drinking.
        "Fear accompanies the possibility of death.....calm shepherds its certainty"
        Originally posted by Topcat
        AWD is just training wheels for RWD.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          it is time to get that socket 478 stuff before they obsolete it. new proc, psu, throw away your agp cards and DDR ram. they love to make you spend to upgrade.
            20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
            I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
            At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
            Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
            04-09-2023, 08:04 PM
          • Ace Perception
            Samsung R530 Bremen motherboard cooling
            by Ace Perception
            I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
            I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
            So I went in pursuit of...
            07-21-2020, 03:05 PM
          • edugimeno
            Stagg sms12p audio amp has water damage
            by edugimeno
            Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
            I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
            There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
            There is only one signal wire connecting the first boards...
            05-24-2025, 06:00 AM
          • Hondaman
            Liquid cooling?
            by Hondaman
            I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
            (After previous generation hardware [Gigabyte] didn't...
            05-08-2025, 09:37 PM
          • RetroComputingGrotto
            Water Damaged Toshiba 48L1435DB
            by RetroComputingGrotto
            I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
            The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
            10-07-2024, 08:23 AM
