Hi everybody.
I've assembled a dual Pentium 3 server and I'm looking for a decent 350-400 W power supply.
At the moment, the server is based on:
- hp tc3100 motherboard (a customized Asus TR-DLS, with a proprietary diagnostic connector, a different bios, onboard Lsi SCSI adapter and only one Ide channel);
- dual P3 Coppermine 1000EB;
- one 512 MB PC133 ECC Registered module;
- a BenQ combo drive;
- a Samsung PL40 40 GB Ide hard disk.
The Samsung unit is temporary: I'm planning to join 3 o 4 Scsi hard disk in a raid 5 array, in order to turn the server into a home nas.
Intially I used a 400 W rated Allied psu: it run fine for a while until the computer suddently rebooted after a 4 hours Memtest session. Since I could firmly exclude blackouts, overheating issues [the heat sinks and the air were barely warm], mistakes with cabling and so on, I opened the psu: I think everybody here knows the [ironic] "high quality build" [/ironic] of Deer/Allied products, but I was simply astonished in discovering my old AT 150w Hipro had same capacity, better brand capacitors, thicker cables and a more ordinated layout. What a crap!
Eventually I replaced the Allied with the other Atx psu I have, an old 200 w Power Win I have used since 1998: it seems it's running fine (just passed a 5 hours Memtest by now), but in the middle run I'll need a more powerful one.
I live in Italy and, due to import and value added taxes, I'm unable to buy outside Europe: Sparkle, Zippy, Topfield and others are almost forbidden due to high prices.
The Corsair VX450 [70 € or $100] divides the "good" from the "bad" psus, but its 5 and 3.3 V rails are a bit weak; for less money, only Fortron emerges from the serious crap (Allied, Tagan, LC Power and others).
Among the rare Oems, I've found two Newton Power: the NPS-400AB A and B. Both are fairly priced, claim 26A on the 5v rail and 24A on the 3.3 one and are new: the A model has an EPS 8 pin connector, has 18A on the first and 10A on the second 12V rail; the B one, instead, has an EPS 4 pin, a 6 pin PCIe and two 15A 12v rails.
I would be interested in the B one: any suggestions?
Thanks in advance,
Zandrax
NPS-400AB A label:
NPS-400AB B:
Thanks in advance,
Zandrax
NPS-400AB A label:
NPS-400AB B:
