Who makes this Dell PSU?
  • Maxxarcade
    • Jul 2006
    • 973
    This is a 300W NPS-300GB out of a Dell Poweredge 1400. It has bigger heatsinks than my 520W Vantec, and has UCC and Rubycon caps. Does anyone know who makes this so I can try to find a bigger version for my main PC? This thing has about 6 years of 24/7 use on it and still looks great
  • Galvanized
    • Mar 2006
    • 468
    Re: Who makes this Dell PSU?
    According to this http://www.jonnyguru.com/SMPS_UL.htm Newton Power LTD . The UL(RL) number on your PSU is E173738.
    I have never heard of Newton but I've only been at this madness a short time, so what do I know?
    The current good Dell PSUs are built by Lite-On.
    Check the pinouts and case size as it just might be ATX standard. But then again a 6 yo Dell is probably proprietary.
    You can check for a PSU by your Dell's model number at http://www.power-on.com/ link it after you find it because the result will indicate ATX standard or not.
    • Shroomie
      • Apr 2006
      • 356
      The Newton Power PSUs I've pulled out of Gateways have been of pretty good quality and used good (usually Chemi-Con) capacitors. They seem honestly rated.
      I haven't been at it long either, so a second opinion would still be good.
      You know there's something wrong when you open up a PSU and are glad to find Teapos.
      Why I don't buy cheap cases!
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        IIRC, Newton Power is/was a subsidiary of Delta Products.
        PeteS in CA
        • gg1978
          • Dec 2004
          • 431
          I personally thought that NPS series was a different line but still made by Delta.. I had a fan die in the NPS 100 W unit in my Linux firewall box, and it was a delta fan.. I know DPS's are certainly Delta, and the font and labeling "style" on the NPS's is just like a DPS Delta...
          They certainly seem to be pretty good PSU's.. I wish Delta would sell their high quality stuff through the retail channel..
          • bgavin
            • Jan 2007
            • 1355
            I just pulled a Newton from a Dell Dimension 4400.
            It was a bit dirty on the inside, but no bulgers. LXG, etc, onboard. I replaced the fan and put it back into the machine. It's only a P4 1700/256/400 so I don't want to waste any money on it, so I put the old PSU back in place.
            The original complaint was DOA, found all three 6.3/3300 KZG in the VRM in bulged state. Replaced with same in MCZ. Board came right back to life.
            The board is Dell exclusive, due to micro ribbon cable that carries Power On, plus LEDs to the board.
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • Akhlz001
              Dell Pro 13 Plus PB13250 Bios Unlock
              by Akhlz001
              Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
              09-20-2025, 07:15 PM
            • master3112
              Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
              by master3112
              I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
              Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
              The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
              07-29-2025, 01:55 PM
              Dell Thunderbolt Firmware
              by SMDFlea
              Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
              Some models have a choice of 2 different firmwares, it depends on the dell SKU.
              The SKU is in brackets (****)
              EDIT: NVM65...
              01-26-2025, 06:22 AM
            • F R 2568
              Dell Latitude 5420 does not start (no post) need help to find the reason why
              by F R 2568
              Hello all,
              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
              If the laptop is only connected to the AC adapter (battery removed):
              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
              The power/battery...
              01-08-2025, 05:45 AM
