MacMini G4 PowerMac ver 2005...
  • patriciopat
    MerlinMac
    • May 2007
    • 68
    Hi good morning, I needed the scheme motherboard model Apple Mac mini G4 model, PowerPC, to know the power connector pins. You know something? thank you very much
  • patriciopat
    MerlinMac
    • May 2007
    • 68
    Re: MacMini G4 PowerMac ver 2005...
    This is the connector MacMini G4 and want to adapt it to connect SATA hard disks ... I should do? thank you very much
      • 31087
      adapters are cheap, but fitting it in the case may be tricky.
      maybe going SSD would be simpler.
      http://www.ebay.co.uk/itm/221674948000
      or using a compact-flash adapter.
      • patriciopat
        MerlinMac
        • May 2007
        • 68
        And this adapter would be better for the upper connector ? greetings
          • 31087
          if that is a sata dvd interface then no,
          but if it's an IDE/ATAPI interface on the adapter then yes - it would work.
          one other thing to keep in mind.
          the apple may not boot a harddrive on the second interface - it depends on the bios.
          are you looking to fit 2 sata drives?
          because if you are - keep in mind you will be generating extra heat.
