Tracking down +5v Standby problem on MB
  • b_s_d
    • Nov 2007
    I have an Intel D865GBC MB that does not power-up because something is holding "PSU On" marginally high. The power supply itself and switch have been ruled out, so the problem is definitely on the MB. There are no signs of damaged caps, hot spots on any chips, or physical damage to traces. The only other symptom is that the LM1117 regulator on the +5V Standby circuit gets very hot - no real surprise as it looks like there is a short somewhere downstream. I replaced the LM1117 on the off chance it was the problem, but still no joy.
    Could a defective cap be causing this? Does anyone know of any tricks for tracking down this sort of problem?
    I'm about convinced the board is DOA, but thought I'd check here before recycling it.
    Thanks and regards, Bob
  • psssst
    Yamaha TSX 120 Standby Problem
    by psssst
    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
    03-01-2024, 07:25 AM
  • theone111
    by theone111
    3. Problem: TV shuts down
    07-22-2024, 10:36 AM
  • Zeonalbasta
    Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
    by Zeonalbasta
    i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
    The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
    09-13-2024, 01:17 PM
  • valvashon
    Insignia NS-LCD19-09 no standby LED; (new problem)
    by valvashon
    Having a new problem with the 19" Insignia that I modified with one of my automatic turn on circuits. That is now completely disconnected so that is not the issue. I was doing some modifications on that circuitry and managed to short something out on the underside of the power board.
    Actually found and bought the service manual (who knew it was even available?!) which brought me to the High Voltage Startup Circuit controller chip.
    Looking up that chip number- LD7575APS brought me to the attached datasheet. I have marked my voltage readings on the schematic sheet (open in new...
    08-30-2023, 10:41 AM
  • Wolf1977
    samsung ue46c8000 problem with standby
    by Wolf1977
    hi to all
    i downloaded the service manual of power supply
    and because it has burnt the ic iCE3BR1765J and the fuse 2 ampere and probably the transformer ic801s i wanted to test the rest circuit if it has not problem so i take a power supply and give 5volt dc to the points + on nr 1 of db803 and - on minus of capacitor cb856
    but when i give voltage the relay rl801s click on and off from the motherboard i suppose something missing or goings wrong
    i connect and the power supply plug on the tv 220volt and i have desolder the transformer
    can someone tell...
    08-13-2023, 12:50 PM
