Cell Phone Battery Naming Protocol
  • TractorGear
    • Mar 2015
    • 40
    Specifically, in my case, the BL-5B.
    Code:
    http://www.newegg.com/Product/Product.aspx?Item=9SIA0PG19P7501
    Dimensions(cm): 4.5 x 0.5 x 3.25
    Is there any connection between the model name/type of a cell phone battery and it's physical size? I'm trying to pack as much stored power into a GPS Tracker unit, and it takes a BL-5B, but while surfing online I see mentions of other, similarly named batteries like a BL-5C, etc...
    I think the GPS unit could take a slightly thicker battery, and the thinking is the larger the physical size the greater the power storage potential so I wonder if a single alpha-numeric increase in the name of the battery mean it's slightly larger. Maybe a BL-6B is 1 mm thicker, or wider, or longer, etc...
  • SluggerB
    Help with trying to fix phone that is not charging (Pics inside)
    by SluggerB
    I have two TCL A30 phones.
    Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
    New Phone: Works fine, bought as a donor board to try and repair Old Phone
    My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
    08-12-2024, 08:11 AM
  • keeney123
    new OS on a Sonim XP5s phone
    by keeney123
    To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
    I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
    05-13-2022, 07:19 PM
  • mikey5791
    Help with Samsung Galaxy J7 Prime phone
    by mikey5791
    Got this smart phone free from a guy who dropped it hard until the lcd display cracked with no seen display.
    Opened it and found the display ribbon cable partly damaged. I charged the phone full in 2 hours time, the led red light turns to green indicate full charge.
    Then i use a usb cable connect the phone to laptop but it only showed as media player with firmware version. Too bad there is no option to check folder.
    Does anyone know any method to check if the phone is working good? Looking forward for any advice and help possible.
    If tested the...
    09-15-2021, 07:54 PM
    Nokia C2-01 RM-721 RM-722 Phone Schematic
    The Nokia C2-01 RM-721 RM-722 was a mobile phone produced by Nokia. The Nokia C2-01 supported 3G and had a 3.2 megapixel back camera. It had a single SIM card. The handset was introduced to the markets in 2011. It replaced its predecessor, the Nokia 2700 classic and Nokia 2730 classic and has improved specifications....
    11-05-2024, 07:40 AM
  • Dannyx
    Cisco IP phone F-up
    by Dannyx
    Good day folks. I had a little f-up over at my new shop today and it made me pretty angry, but at the same time it determined me to try and figure out what could've happened there. This is only going to be a speculative discussion since I don't know the exact layout of our network, hence I don't know what's going on past our room. So:
    The repair shop where I sit is situated in a remote building down the street from the main building. There's a Cisco IP phone in this room, a 7911, like the rest of the company uses. There's obviously some sort of networking going on between the two...
    11-27-2018, 12:39 PM
