Power Supply!!!
  • Dexter AJ
    • Sep 2007
    Power Supply!!!
    Hi there I am currently having a 350watts power supply while I am using a P4 2.4GHZ intel original.Is this power supply enough or should I upgrade it to a higher power supply?And will upgrading it have any bad effects on my PC and what damage can the 300watts power supply do to my pc IF its not adequate???
    DeXter^AJ^...
  • kikkoman
    • Jul 2007
    • 691
    Re: Power Supply!!!
    If it's a good one, there's no need to upgrade. If it's a crappy one, you're lucky that it's still running.
    Don't upgrade to a higher PSU, but to a BETTER one.
    Worst case is damage to any of the system's components in case it fails. Worstest case is damage to EVERY component.
    What brand is yours?
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • starfury1
      • May 2006
      • 1256
      Re: Power Supply!!!
      as above
      A 350 Watt "Quality" supply is going to do a better job then a supposedly 500 Watt piece of crap
      What Brand and Model,
      There are some that are fine supplies with a recap but some are just pieces of crap waiting to kill your system.
      Please list details
      cheers, welcome
      • PeteS in CA
        • Aug 2005
        • 3586
        • USA, Unsure of Planet
        Re: Power Supply!!!
        You can't trust the power ratings on junky brand power supplies. They may be able to deliver that rated power for a few femtoseconds. Some internal pix of power supplies that have been posted here had me scared to draw half of the rated power for any significant amount of time (and I worked in power supply design, manufacture and tech support for almost 25 years).
        PeteS in CA
        • gonzo0815
          • Feb 2006
          • 1600
          Re: Power Supply!!!
          Unless you are getting problems you can stick with it.
          There are many commercially sold systems with FSP AKA Fortron or other good psu`s out there.
          Any way, if you want a new psu for safeties sake, i would recomend a Seasonic S12 Series one, may be in the range between 330 to 500w.
          But this is only recommended, if your system is featuring the fore pin p4 12v molex connector, as any new designed psu has it`s most power at the 12v rail.
          • Dexter AJ
            • Sep 2007
            Re: Power Supply!!!
            Well i using the Power supply of a company named Infinity...U guyz may know of it or not co i live on the different part of the world Pakistan...Our markets loaded wit china stufff.....Any waz my sys usually restarts and wont come back to life easily like its a headach having it stared agian but once it started it gives me some thermal problem message...I changed the fan the sink checked the caps but now the senirio is like its rate of restart hav decreased but yes its still not reliable and now its not giving me any of the thermal message but still its tuff to brong it to life...Any idea like wats going on???
            DeXter^AJ^...
            • starfury1
              • May 2006
              • 1256
              Re: Power Supply!!!
              well cant find any ref directly to infinity as a psu...cases plus psu yes.
              So can only assume a generic of some kind
              (there is an enermax infinti but not at that wattage)
              As to damage from the psu, yes it is possible ....some are known MB killers but really depends on the psu
              from what you say, rebooting is one symptom that caps can cause but thermal is of course heat related.
              (was it some warning on CPU temp? just wondering)
              if the supply has been used for some time it could have blown caps and your are also saying starting it is an issue.
              The short answer is change the psu (to preferable a new good quality unit ) and see if it still happens.
              if it does work ok with a new one, you know the psu is either failing (probably caps wise) or not up to the job...failing is more likely
              (you could crack it open and have a look at the condition of the caps)
              If you still have the same issues them its most likely some issue with the MB system
              caps can look fine and still be failed.
              upgrading (as gonzo said) if you can find one at a decent price, but there are others so have a read around the forums see what good and whats crap.
              if you dont want to spend the money out right see if you can borrow one from a known working system
              (thats compatible of course)
              My thought is psu failing/failed but thats noway conclusive!
              (I dont know all the details or history of the box)
              HTH
              Cheers
              • gonzo0815
                • Feb 2006
                • 1600
                Re: Power Supply!!!
                In that case, i would say the PSu right place to start troubleshooting.
                If the systems won`t come back after a reboot, this is a clear sign of a bad PSU.
                Probably the standby circuit is bad or encountered badcaps.
                • Dexter AJ
                  • Sep 2007
                  Re: Power Supply!!!
                  To be frank i brought the PSU a month ago.But hay i m going to rip apart this one and see how is it inside...Its a real pain in the neck...
                  DeXter^AJ^...
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    Re: Power Supply!!!
                    Don`t get me wrong, i do not say, that it IS the PSu, as it is obvious that i can`t do that without having it examined.
                    But from the little i know about your problem, i think it is very likely that it is the issue.
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                      03-31-2024, 02:12 PM
                      07-01-2024, 06:34 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
                    • caspian
                      Can Ammeter damage Power Supply?
                      by caspian
                      Dear Members,
                      My DC linear Lab Power Supply does not display the current and voltage correctly. Thus, I am going to connect an Ammeter/Voltmeter Module to the DC output of the power supply. Then, a load will be connected the takes about 1-5volts with 0.1-1.5Amps.
                      But I heard If I connect an Ammeter to the output of the power supply, then the Ammeter module is not isolated from the power supply so that the Ammeter can damage the power supply.
                      Is this true?
                      I have attached the photo of a sample Ammeter module that I am going to buy....
                      06-05-2022, 01:42 AM
