Monitor's 1920x1080 vs. native resolution
  • Vivi
    Banned
    • Sep 2014
    • 101
    I've got this dell monitor se198wfp 19 inch with a native resolution of 1440x900, BUT, my graphics card (AMD Radeon 5450) supports the resolution 1920x1080. so can this monitor display 1920x1080 and look better than 1440x900?
  • ddscentral
    • Mar 2008
    • 151
    • Lithuania, EU
    Re: Monitor's 1920x1080 vs. native resolution
    No, 1440x900 is the max resolution supported by that monitor.
    Some monitors do support setting resolution above their native, but it will result in a scrolling display.
    • Vivi
      Banned
      • Sep 2014
      • 101
      Good to know, and also, setting a pc game's resolution to 1440x900 will actually have a better display?
      • c_hegge
        • Sep 2009
        • 5219
        Yes. The native resolution on the monitor will always have the sharpest picture. Most of the time, the pictures on LCD monitors will looks lightly fuzzy if the native resolution is not set.
          • 31298
          try to match the panel frequency too.
          lock the vsync at that rate.
          • Vivi
            Banned
            • Sep 2014
            • 101
            I do see what you mean, text looks tiny, but I'm confused on whether or not I'm getting a better sharper image at this resolution or not. Maybe my eyes are playing tricks on me...
            And also, what is vsync? I don't see it in the AMD Catalyst control center.
            • mariushm
              • May 2011
              • 3799
              Don't bother with it. Simply put, it only matters in some games and most of the time it's best to leave it on the default setting (off).
              Set the monitor to the panels standard resolution (or native resolution, 1440x900 or whatever it is) and configure the refresh rate to 60 Hz. LCD monitors don't really have the concept of refresh rates (in the same sense as old CRT monitors) and the electronics and panel don't really do more than 60 updates a second, so 60 Hz selected there is fine. Higher number won't do any better.
              If text looks too tiny at the native resolution, don't change the resolution to fit your needs, right click on Desktop, select Screen resolution and then click on "make text or other items larger or smaller" (in windows 7), and from there you can make texts larger or smaller without affecting the rest of the image (windows, movies, applications etc)
              If you currently use a VGA cable, you should also change it with a digital connection. The DVI connector on the monitor will give you a better image quality and the video card should have a DVI connector... so get a DVI cable. If it only has HDMI and VGA, then you can buy HDMI to DVI adapters for very cheap, a few dollars.
              If you do this, then you would also have to check in Catalyst Control Center the option My Digital Flat Panels > Pixel Format and make sure you have RGB 4:4:4 Pixel Format PC Standard (Full RGB) selected. This option only matters when the connection between monitor and video card is digital, you may not find it when you use a classic vga cable (analogue).
              • Vivi
                Banned
                • Sep 2014
                • 101
                I'm connected using DVI to HDMI, and the monitor's max refresh rate is 75hz, is that better?
                And I've switched the resolution back to 1440x900 75hz and everything does look a lot better.
                  • 31298
                  if you set the refresh rate higher than the panel it will just buffer and discard some of the frames.
                  you just generate extra heat on the videocard for nothing.
                  that's why i mentioned the vsync,
                  some people run games at 200-300fps thinking it's better and all they are doing is stressing the GPU for nohing!
                  • Vivi
                    Banned
                    • Sep 2014
                    • 101
                    so where is vsync located on the AMD Catalyst control center?
                      • 31298
                      no idea, i use nvidia.
                      get the service manual for your monitor first, and see what the native panel frequency is.
                      • mariushm
                        • May 2011
                        • 3799
                        The monitor has analogue and digital input.
                        The old CRT monitors worked by moving an electron beam over the surface of the screen, heating up phosphorus dots on the glass to the point where they produce light. However, by the time that electron beam reaches the bottom of the screen the phosphorus dots start to cool down and they get darker.
                        So with CRT monitors, the electron beam had to move across the screen lots of times each second to maintain the brightness across the screen and prevent flicker.
                        The minimum number of updates is considered to be 60, hence the value of 60 Hz. However, a large majority of people have eyes more sensitive and a very common and recommended refresh rate was 75-85 Hz.
                        LCD displays work differently, they don't have an electron beam to heat up dots and produce light, so the brightness doesn't change, there's no flicker, there's no concept of minimum refresh rate. From the moment the monitor receives a picture, it takes about 3-15 ms to turn all the pixels on or off, so basically the image changes instantly and then it doesn't need to be refreshed constantly.
                        With LCD displays, that value of 60 Hz refers to the maximum number of opportunities to change the image on the screen. 60 times a second, the monitor receives a new snapshot and if there's some differences between the already displayed picture and the new picture, the monitor changes the pixels.
                        The processor inside the monitor is designed around this value of 60 because it's standardized, so if you select a larger value the processor inside the monitor will simply ignore the extra information it receives. A larger value selected there won't make any difference.
                        vsync stands for vertical synchronization. With CRT monitors, when the option was enabled, it forced the video card to wait until the electron beam reached the bottom of the screen and move back to the top.. then the video card worked on a new picture.
                        This prevented an effect called "tearing", which was most noticeable in games when you did a slow 360 rotation .. here's an extreme example: http://zoneitastuces.com/wp-content/...en-tearing.png
                        Tearing used to be a problem in the past but modern video cards and video card drivers aren't that much affected and it's more beneficial to leave that vsync off. Don't mess with it, if there's some bad (or unoptimized) game that displays tearing then you would be able to enable it from game's menu or by creating a game profile for that particular game.
                        A radeon 5450 doesn't have that much processing power, you won't save energy if you enable vsync and fix the update rate to 60fps instead of letting a game run at 100-200 fps, or whatever fps it manages. If you have a game that works so fast on a radeon 5450, you're better off raising the image quality from game options until the framerate drops to around 60 fps.
                        • chozo4
                          Nothing Special
                          • 134
                          I gave up trying to explain that to others long ago sadly. Apparently 'higher fps means you play better' according to some poeple. Like 100,200, or even 1k fps (despite highest possible image quality) would make someone would suck any less than they already do. Some actually seem rather baffled when mentioning consoles play at only 30fps and will still simply refuse to accept that capping the fps will result in better gameplay due to less strain on other hardware. CPU and OpenGL comes to mind in that case or a GPU running at XYZ frames with occlusive culling enabled and the ilk.
                          Even crap caps can be useful... such as blank rounds for prop gunfights.
                          • mariushm
                            • May 2011
                            • 3799
                            Well, it's a good thing that you're wrong then.
                            Consoles don't limit the framerate to 30fps because they want to, they limit it because there's not enough processing power in the console to render everything and to also leave room for AI, sound processing and everything else.
                            It's also a simple and easy way to cut development costs, after all why spend money optimizing the code to run at 60 fps when you can just say it's for "cinematic" reasons your game only works at 30fps.
                            A lot of games aren't even 1080p or 1080i, they're using resolutions like 1440x1080 or 960x1080 and they upscale in hardware the image sent to the TV. You can see here a list of native resolutions: http://www.ign.com/wikis/xbox-one/PS...and_Framerates
                            Higher framerate does make a game better to play even though you still only get 60 updates per second on the screen, unless you go with a monitor capable of 120 or 144 updates a second.
                            It depends on how the game is built and a lot of other things... for example lots of multiplayer games have network code that works differently depending on the game's framerate (more network traffic, more updates, smother multiplayer if you have more fps)
                              • 31298
                              @chozo4
                              the same fools thats pend $100 on a "gaming" mouse.
                              • ReggieReddog
                                • Nov 2014
                                • 6
                                I dunno man; I'm not a big fan of screen tearing. I would think that would negate any minor network advantage you might get. I turn on Vsync any time I think my card can handle a solid 60fps.
                                  • 31298
                                  tearing depends on what your doing,
                                  if you like side-scrolling games like i do then tearing is pretty much constant without vsync.
                                  your less likely to notice any on 3D first-person stuff.
                                  • ReggieReddog
                                    • Nov 2014
                                    • 6
                                    Not trying to be contrary, but I gotta disagree. A lot of first person games involve looking left and right; which is where the tearing comes into play. But anyway, we are straying a bit.
                                      ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook Specification for Upgrade or Repair
                                      This specification for the ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To boardview and 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard...
                                      09-07-2024, 02:50 AM
                                      ASUS 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year Notebook Specification for Upgrade or Repair
                                      This specification for the ASUS 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year boardview and 14.0 FHD 1920x1080 Pentium Gold 7505 4GB 128GB with M365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                      09-07-2024, 01:30 AM
                                      Microsoft Surface Go 2 Go 2 Specification for Upgrade or Repair
                                      This specification for the Microsoft Surface Go 2 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Go 2 boardview and Go 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Microsoft Surface Go 2...
                                      09-06-2024, 08:40 PM
