A mobo with a tube?
  • pentium
    • Mar 2006
    • 2778
    A mobo with a tube?
    A while back I remember seeing an article a motherboard that used a single tube for it's audio amplifier. I can't seem to remember the brand and I can't find anything on google. Anyone know about the board I am talking about?
    Find Nedry!
    Check the Vending machines!!
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: A mobo with a tube?
    no sorry
    http://www.digit-life.com/articles2/...ube/index.html
    nope
    http://www.neoseeker.com/Articles/Ha...aopenax4btube/
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Aopen AX4B-533 P4 board. I've recapped quite a few of those. A very unique board, I must say.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • stevo1210
        • Oct 2006
        • 4156
        wow. that's something i've never seen before....
        • pentium
          • Mar 2006
          • 2778
          Thanks topcat. What kind of caps were they? Choyo?
          I wonder how bad their heat output is? How much power do you suspect is needed?
          Oh great, a closer look shows no real tube model number like you usually see in old tube sets.
          Find Nedry!
          • starfury1
            • May 2006
            • 1256
            I had forgotten about that one till you mentioned it....wouldn't have remembered who made it or what model yeah valve state MB..... ok ok I know its only for audio
            AOpen AX4B-533 Tube
            AOpen AX4GE Tube-G moederbord review
            AOpen AX4GE Tube-G another review (link) page 2 (pics there)
            TubeSound Motherboards:
            There are four new models of TubeSound enabled boards, the AX4GE-Tube, AX4PE-Tube, AX4GE Tube-G, and the AX4PE Tube-G. The PE and GE suffixes denote which version of the Intel 845 chipset is used; the GE variants feature Intel's 82845GE integrated graphics solution. The G suffix denotes the value version of the motherboard, without the extra Promise SATA/ATA133 chip onboard.
            Page1 1 link
            cheers
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              If that tube has a 100V-150V plate voltage, I'm curious how it is derived and how safety regs compliance was achieved, if it was.
              PeteS in CA
              • gonzo0815
                • Feb 2006
                • 1600
                That was the exact same question which was coming to my mind after seeing the step up converter ;-)
                I think they had to place a isolation shield over the bottom side to accomplish this.
                May be TC can enlighten us.
                • pentium
                  • Mar 2006
                  • 2778
                  Same here. where's a link to the mobo manual. It should tell all.
                  Find Nedry!
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    One of the more daunting challenges for AOpen engineering team in developing the AX4B-533 Tube was the process of powering the tube circuitry that requires high voltage of up to 100V from the power supply to properly operate the tube. By incorporating a switching mode power supply for the tube circuitry that can truly rival solid-state amplifiers, then employing a maxim 668 DC-DC voltage converter to provide ample voltage for the tube to function under optimal conditions - correct audio playback is achieved.
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      Well, from the picture i think it is showing the inductor or converter as trough whole component.
                      Thus the high voltage is unprotected without any shielding
                      At least i would not have the balls, to let the air isolate against the case..
                      • marco916
                        • Feb 2008
                        • 11
                        Sorry for the late post, I just joined bad caps forum today and noticed you guys were taking about the Aopen board with the vacuum tube. Actually badcaps.net replaced my caps on mine a few years ago, and still use this board today with Vista and Intel P4 3.2ghz CPU, the audio output sound is nice when using it in conjunction with a tube amp. That's when you really here the sonics. Here's some pics of my board after finishing it up in the case.
                        http://picasaweb.google.com/ty.monro...19049134339122
                        • pentium
                          • Mar 2006
                          • 2778
                          Was there an older replacement for the tube?
                          I have a rubbermaid tub filled with tubes.
                          Find Nedry!
                          • marco916
                            • Feb 2008
                            • 11
                            The MB uses the Russian Sovtek 6922 tube which is in use today with many vacuum tube audio gear. If you have a rubbermaid tub full of these, I would suggest to eBay half of them, and save the rest for another 20, 30 years when they become very rare to buy. I'm sure you will get a pretty Canadian Penny for them.
                            • bgavin
                              • Jan 2007
                              • 1355
                              [hijack]
                              Hey Marco, I see you are in Sacramento. I'm in Orangevale.
                              [/hijack]
                              • marco916
                                • Feb 2008
                                • 11
                                Hi there bgavin, I'm actually in Antelope, but nobody knows where thats at. (:
                                • drchaos67
                                  • Nov 2008
                                  I just finished recapping my AX4B-533 Tube motherboard today. All the electrolytics 1000uf and larger were bulging and most of them had leaked. I have been using this board for years now and recently it began to require two boots to be stable. From day one, if the room temperature was below 70F, the sound drivers would not initialize. It will be this fall before I discover whether or not recapping solved this particular problem. There have been a few other issues such as the chipset heatskink falling off after one of the (soldered in) U-shaped pieces of wire holding the spring clip in place mysteriously worked loose from the board. According to a tube audio expert I know, the tube circuit has a cathode-follower arrangement, implying the designers did not wish to operate the tube toward the limits of its gain, so the tube sound effect is nice but relatively mild. Unless you know what you are listening for (and have a nice audio system to play it through) you will not notice it. Also, I found the board was mediocre at best in the capacity of <<recording>> audio, so I still use handmade custom TI C32 DSP boards with external A/D - D/A pods (on a P3-800 running Win95OSR2! Hey, don't laugh - with no bloat and no DRM it's faster than a lot of modern multi core setups running Win7!) for recording. Anyhow, to the topic at hand - recapping the AX4B-533 Tube: All of the "Leylon" caps, black and gold on the plastic sleeves, were bad. There were (5) 2200uf 16V at positions TC7,TC11,TC13,TC42 and TC43. (3) 1500uf 6.3V at positions TC5,TC16 and TC29. (5) 1000uf 6.3V at positions TC8,TC26,TC30,TC32 and TC33. The worst one was the 2200uf 16V between the 7806 regulator and the tube. Everything seems to be working correctly after the job but a little time will tell - the side cover isn't going on for a few more days at least!
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    Lelon are a known bad brand. It's a shame that they used bad caps on such a nice board. As for recording - it's a regular AC'97 codec after all, no wonder it gets beaten by an external D/A converter.
                                    A working TV? How boring!
                                    • marco916
                                      • Feb 2008
                                      • 11
                                      drchaos67, you still active? is the AX4b-533 still running, I found another AX4B-533 few years ago on Fleabay, same issue like my other board, all blown Lelon and Nichicon caps, going to try to recap myself this time.
                                      • DCJack
                                        B&K 707 tube tester. I need help.
                                        by DCJack
                                        Hi everyone!
                                        I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                                        Initially I noticed that I was not getting the red on-light to turn on, but it...
                                        03-05-2024, 05:05 PM
                                      • MrCommunistGen
                                        Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                        by MrCommunistGen
                                        My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                        I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                        07-12-2021, 05:11 PM
                                      • Schoenradt
                                        ECH81/6AJ8 Vacuum Tube Question
                                        by Schoenradt
                                        Recently I acquired an Eico HFT 92 AM/FM radio made back in 1958. The unit has had some decent modifications done such as replacing the rectifier tube with silicon diodes and replacing the main filter capacitor with electrolytic capacitors. When I powered it up FM wouldn't tune past 105Mhz. I checked the FM tuner front end assembly and found a capacitor not soldered to the coil from the Plate B+ to and ground on the other side of the coil. Some calibration was needed on the trimmer capacitor on the tuner. My question is AM is extremely weak. When I tap on the tube I get all kinds of snapping and...
                                        06-10-2021, 05:49 PM
                                      • ChaosLegionnaire
                                        by ChaosLegionnaire
                                        09-13-2022, 09:02 AM
                                      • jinu_j
                                        How to test Subwoofer Amplifier with only a multimeter
                                        by jinu_j
                                        Hi Folks
                                        Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                        Problem
                                        I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                        Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                        Any advice would be appreciated...
                                        08-29-2024, 02:05 AM
