I am curious of what PCs (Intel/AMD) with a PCI bus which use a POST diagnostic code address other than 80h - not very likely, but could be possible.
PCI bus PCs and POST code addresses other than 80h
TCL LED TV Service Menu Code
LG LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by dmccul2698Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
1). Understand the schematic and check the connections between the EEProm and DSP
2). Check the functionality of the EEProm
I don't know if this is the unit's problem but it's a place to start.
I have little to no electronic experience...6 Photos-
Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
what is wrong with your PC in just seconds. It saves you time and money.
Our new and improved design...-
11-01-2024, 06:29 AM -
by Sorrow1Hi,
I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
When I recorded video of POST card and played it in slow... -
by DynaxSCHi Folks
I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works... - Loading...
