Bad Caps
  • toastygoodness
    • Jul 2005
    • 813
    Bad Caps
    Are OST and Teapo still considered badcaps? Does ECS still use them exclusively? I'm kind of stuck in a ditch with money and my compy's broke so the only board in my range (plus a Sempron 3000+) is the ECS C51GM-M at Neweg.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Bad Caps
    I wouldn't trust it. Teapos are known to go open, and of course you know OST all too well.... Recap it before you install it. Preventative maintenance is the best way!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • toastygoodness
      • Jul 2005
      • 813
      Re: Bad Caps
      oh man... are there any good budget brands? i need 2x ATA ports and almost no new boards have that.
      • tazwegion
        • Jun 2006
        • 444
        Re: Bad Caps
        The last X-series (budget) motherboard I had from Asus had decent capacitors IIRC... can't comment on the AM2 socket variants though
        Viva LA Retro!
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
