BIOS Lock. Not sure if it's worth the salvage
  • pentium
    • Mar 2006
    • 2778
    Yay. Another BIOS issue with another Panasonic product.
    A friend gave me one of his Flea Market Specials: a Panasonic CF-U1 toughbook. It has the regular accessories like the stylus and batteries and panels but no hard drive and the BIOS lock active ("but what if someone changes my ram??"). I've been throwing every password I could think of at it for two weeks now and it's still locked. There's no technical documentation available so I do not know the CMOS reset procedure and it appears to be NVRAM based so pulling the battery doesn't clear it. In the honorable opinions of Badcaps do you think it's worth continuing to try and salvage or just giving it back to him to sell for parts?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • bossapplesauce
    • 7
    Re: BIOS Lock. Not sure if it's worth the salvage
    Unit has a dedicated security chip. Unless you want to figure out which NVRAM it's using, build a chip reader and then interpret the encrypted machine code, I'd say it's not worth the hassle. Sorry bud.
    In case you don't have it, here's some documentation on the unit:
    Code:
    http://www.spiritdatacapture.co.uk/manuals/panasonic/CF-U1%20Reference%20Manual.pdf
      • 31017
      if the TPM chip is removeable then bin it.
      btw, most of them have a reset method such as a pair of pads to link on the board.
      • pentium
        • Mar 2006
        • 2778
        Forget it. I'll find a better computer.
        Find Nedry!
        • Time2Retire
          • Aug 2012
          • 256
          Did you try this?
          http://www.cgsecurity.org/wiki/CmosPwd
          • ThePCDoctor
            Retired Tech.
            • Sep 2011
            • 59
            Just curious.....
            Is there a separate CMOS battery in that little PC?
            If there is, removing all power from the unit, including the big battery pack ,and then removing the little CMOS battery for at least half an hour, will usually drain the CMOS memory chip of all its little electrons.....thus erasing the user set memory (passwords, etc.)
            Admittedly, I've not had to do that on a laptop, but it works a treat on Desktop PC's.
            I've had PC's that seemed to be completely DEAD, but after clearing the CMOS with the above procedure, they booted up and ran like new.
            I'd love to have a crack at that Panasonic. That's one heck of a tough little PC!
            I always wanted one, but could never afford it.
            Good Luck,
            The Doctor
            Experience is truly the best teacher.
            Backup! Backup! Backup! Ghost Rocks!
            • SteveNielsen
              Retired Tech
              • 2327
              That's not going to work in this guy's case. It stores the pword in nvram, not in cmos.
              • ArtMov
                [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                by ArtMov
                Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                1. I made overclocking lock disabled the default in amibcp
                2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                03-31-2023, 01:30 PM
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
              • BrentH561
                Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
                by BrentH561
                Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
                Here is the hardware identification specs:
                HP EliteDesk 800 G6 SFF
                Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                Serial No: MXL1223499
                Product No: 26S74UT#ABA
                BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most
                08-23-2024, 08:36 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
