BIOS locked itself
  • pentium
    • Mar 2006
    • 2778
    BIOS locked itself
    So the CR2032 CMOS battery in my CF-25 (MK III) toughbook died and this causes the machine to not POST. After I replaced it I went into the BIOS and discovered the supervisor password was set. I could adjust power management and enable/disable the trackpad but everything else is locked out.
    I reset the CMOS twice by shorting the CR2032 and it's still there. I never set passwords in the CMOS. I have no clue what the hell the password could even be. I have the laptop pulled apart again with the battery removed and the terminals shorted but I have no clue if this is the "proper" way to reset on a toughbook.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
    • 31028
    Re: BIOS locked itself
    you need a service manual.
    most lap's have a dipswitch or pair of pads you can short to clear the cmos.
    ibm's dont count btw - those bastards have a special eeprom with internal security (anti-glitch) feature and wireless (NFC) access.
    i hate those - you have to dump them wih a homemade interface!
    just to add, shorting the battery holder wont work - there is a diode after it and the ram will also have a cap across it.
    shorting the holder for a day or 2 may work - but maybe not.
    • pentium
      • Mar 2006
      • 2778
      I have no clue where at this point I could find the service manual for the CF-25.
      Find Nedry!
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        apt-get remove bios-passwd?
        on a serious note: there are laptop BIOS password cracking disks around the 'net.
        Follow the white rabbit.
        • pentium
          • Mar 2006
          • 2778
          Well I guess I can look around and see if there is anything. There's a lot of shady apps out there.
          Find Nedry!
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            who makes the BIOS?
            award BIOS backdoor passwords:
            ALFAROME BIOSTAR KDD ZAAADA
            ALLy CONCAT Lkwpeter ZBAAACA
            aLLy CONDO LKWPETER ZJAAADC
            aLLY Condo PINT 01322222
            ALLY d8on pint 589589
            aPAf djonet SER 589721
            _award HLT SKY_FOX 595595
            AWARD_SW J64 SYXZ 598598
            AWARD?SW J256 syxz
            AWARD SW J262 shift + syxz
            AWARD PW j332 TTPTHA
            AWKWARD j322
            awkward
            AMI BIOS Backdoor Passwords:
            AMI BIOS PASSWORD HEWITT RAND
            AMI?SW AMI_SW LKWPETER CONDO
            Phoenix BIOS Backdoor Passwords:
            phoenix PHOENIX CMOS BIOS
            Misc. Common Passwords
            ALFAROME BIOSTAR biostar biosstar
            CMOS cmos LKWPETER lkwpeter
            setup SETUP Syxz Wodj
            Other BIOS Passwords by Manufacturer
            1. VOBIS & IBM = merlin
            2. Dell = Dell
            3. Biostar = Biostar
            4. Compaq = Compaq
            5. Enox = xo11nE
            6. Epox = central
            7. Freetech = Posterie
            8. IWill = iwill
            9. Jetway = spooml
            10. Packard Bell = bell9
            11. QDI = QDI
            12. Siemens = SKY_FOX
            13. TMC = BIGO
            14. Toshiba = Toshiba (some will reset BIOS if the left shift key is held down during boot)
            on an interesting note: this is what inspired the IBM password http://www-03.ibm.com/ibm/history/ex...rage_3330.html
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              try killcmos, seems to be a common thing for these toughbooks.
                • 31028
                what prof said - just seen this:
                http://www.computing.net/answers/har...ord/63362.html
                  • 31028
                  http://www.majorgeeks.com/files/details/killcmos.html
                  and incase you need it.
                  http://www.freedos.org/
                  • pentium
                    • Mar 2006
                    • 2778
                    The POST has an IBM copyright so I assume it uses a licensed BIOS. Unfortunately the backdoor password did not work.
                    Anyways, killcmos.com did clear out both the CMOS settings and that nasty supervisor password so all is well again. Thank you.
                    Setting the supervisor password with a CMOS change. What a peculiar bug....or security feature?
                    Find Nedry!
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      Originally posted by pentium
                      wow. Killcmos did indeed work.
                      Setting the supervisor password with a cmos change. What a peculiar bug....or security feature?
                      bug.
                        • 31028
                        btw, when i saw your post title i thought you had an HP NC6200.series
                        that would have been a bitch - best leave that for another day!
                        • pentium
                          • Mar 2006
                          • 2778
                          I've seen my share of laptops with various passwords set.
                          Find Nedry!
                            • 31028
                            yea, but the 6200's have a design fault that sets them and a TPM chip to keep them held!!
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4957
                              • New Zealand
                              I think my MSI 790GX-G65 has a BIOS bug that causes a password to be set; if at POST I press F11 to enter the boot device menu and after that press Delete to enter the BIOS, it will ask for a password until I clear the BIOS settings.
                              -David VanHorn
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • dr_crx
                                Dell 7740 Bios locked J3JSD43-8FC8
                                by dr_crx
                                Hello i need help please
                                i have DELL 7740 ST: J3JSD43-8FC8
                                i tried to read bios bit i think it is wrong because the size of the file is around 1mb
                                anyone can help to show its location on motherboard please.
                                i attached the results file the IC i read is : winbond 25q80dvsig
                                i don't know if its the needed bios or another bios on the motherboard.
                                thank you in advanced for your help...
                                07-11-2025, 12:22 AM
                              • Vesko356
                                by Vesko356
                                08-11-2023, 03:27 AM
                              • fulaphex
                                Lenovo Thinkpad X13 Gen 3 AMD locked bios
                                by fulaphex
                                hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
                                I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....
                                07-09-2025, 07:04 PM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
