Annoying power save problem
  • Maxxarcade
    • Jul 2006
    • 973
    I've been having a slight problem with power save on my new system... I have it set to turn off the monitor after 15 minutes, but a lot of the time it will shut off for about 1 second, then come right back on. This is really annoying, since I'm trying to preserve the CRT on my 24" Sony monitor.
    I've checked to see if it is the mouse causing it, and that was not the problem. What else should I check?
    My motherboard is a Gigabyte GA-M61P-S3 (I think), socket AM2.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Annoying power save problem
    the constant on and off (heating and cooling) of the power saving is harder on a CRT than it is being on all the time. The21" and 24" FD trinitron tubes had problems with the focus rail detaching in the neck of the tube, so the cooling and heating is extremely harmful to them. With my old sony 24", I left it on all the time, never shut it off, even at night. It lasted over 3 years like that. I just used the plain black screen saver, which kicked in after 5 minutes of being idle.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Maxxarcade
      • Jul 2006
      • 973
      I'll just use a normal screensaver then, either something all black or with very little graphics and a lot of movement.
      My last 21" FD Trinitron is still going, despite having some screen burn form the taskbar and being a bit out of focus. I just wanted to keep the 24" in the best shape possible because I need it to last a few years. That is unless I can get a 25" or larger LCD with decent PQ for under $500 real soon
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        http://www.newegg.com/Product/Produc...82E16824009089
        That replaced my last CRT monitor I owned (24" FD trinitron). No comparison. The LCD blows the trinitron away.
        Team : 49813
        Join in!!
        Team Stats
        • Rainbow
          • Aug 2005
          • 1375
          I use 15 minute timeout to DPMS OFF mode (and also blank screen saver after 3 minutes) on my 15" ADI monitor since it was new in 1999. It still works fine, although the contrast is becoming worse.
          • Maxxarcade
            • Jul 2006
            • 973
            Which one was it? I get a list of several monitors from that link.
            The two main reasons I still use CRT, are for contrast ratio (blacker blacks) and flexibility of resolution without loss of quality. How would you rate your new LCD for contrast ratio?
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              It's rated at 1000:1 CR, its the Acer 24" AL2423W monitor. blacks are black, best res is 1920x1200, and its absolutely gorgeous. 640x480 wasnt too great looking, but comparable to a crt, its not lacking. I played UT on a few times to test things out, no input lag, all the pretties turned on, and no complaints. There are better brands out there this size, but not in this price range. I can't even look at my 24" trinitron anymore, it gives me a headache, and there's nothing wrong with it, the LCD is just so much more crisp. I gave the trinitron away to a friend of mine who needed it.
              Team : 49813
              Join in!!
              Team Stats
              • Paul S
                • Sep 2006
                • 326
                When you first posted that link, it lead to the Acer 24" LCD. It also said that it was out of stock. Now it says that the link has been deactivated.
                I just got a Samsung 24"LCD, but it cost a few more $$$ than the Acer. I use it for watching HDTV with my MythTV PC:
                http://www.newegg.com/Product/Produc...82E16824001222
                Although, now I see that there is a newer model that is cheaper.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  Maybe they aren't carrying it anymore. I have a TV tuner in my PC, but it looked like crap even on a CRT (ATI TV Wonder pro PCI). A DVD is f'ing beautiful on this Acer, and games are also great. That Samsung is nice!! If this one bites the dust, that bad boy would be my next LCD purchase!!
                  Team : 49813
                  Join in!!
                  Team Stats
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • Duranitron
                    Asus x512dk rev 2.1 power on problem
                    by Duranitron
                    When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                    Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                    11-26-2024, 10:22 PM
                  • EazyBone
                    LG OLED55C9PUA power problem
                    by EazyBone
                    Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                    Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                    I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                    The power supply to t con is different story.
                    This...
                    06-23-2023, 07:43 AM
                  • Dr.d
                    Help please..Lenovo ideapad 5 14itl05 power and charging problem
                    by Dr.d
                    I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                    Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                    04-05-2024, 11:48 AM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
