peloton monitor motherboard headphone jack replacement
  • Gadjet
    • Aug 2012
    • 248
    This jack was broken off the board and I can't seem to find a replacement anywhere. it has an inclined female end. Any help is appreciated
    • 31055
    those are used on tablets,
    it looks o.k. - the pcb looks fucked though.
    why is it all scratched up?
    • Gadjet
      • Aug 2012
      • 248
      well there is a gold piece missing from the jack, and it pulled the pads from the board, I scratched around the pads to see if there were any traces. I'll cover them with a mask after adding new pads.
        • 31055
        you can probably find the jack on aliexpress,
        you will probably have to epoxy it down and then run wires to the signal source though.
        • dhenion
          Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
          by dhenion
          I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
          The original board was:
          ASUS X510UNR REV 3.0 A
          The replacement board is:
          ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
          It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
          01-30-2024, 01:45 PM
        • baletak
          Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
          by baletak
          had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
          I have updated laptop model number.
          1) I did not find the way to update laptop serial number - I have this one.
          2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
          Hope to find someone to help me with this as I am hitting dead end at the moment.
          Many thanks
          Miro
          05-23-2025, 01:21 AM
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • Dergal T Stonkerson
          LCD monitor motherboard not powering up
          by Dergal T Stonkerson
          I have a faulty motherboard controlling G150XG01 LCD monitor. Pictures attached of two separate motherboards. I have being searching online for a schematic of the boards, none of the codes on the boards are giving any results when searching. Is it possible to get schematics for these? Is it possible to repair these surface mount pcb's, what are the common faults?
          Thanks in advance for any help/advise....
          08-15-2024, 04:00 AM
        • glovecaps
          by glovecaps
          11-25-2024, 04:23 PM
