Can't find the main SOC on a board?
+ More Options
Posts
  • japlytic
    • Oct 2005
    • 2086
    Certain SOCs such as the Broadcom BCM2835 as used in the first Raspberry Pi model can have a "POP" memory module installed on top to save board space.
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
