About fans and bearings...
  • Aleksi
    • Aug 2006
    • 20
    Thought I'd paste a link to a FAQ made by Dorothy Bradbury
    Really good reading for most people, might help people with the loads of BS used by fan relabellers and websites pushing them, like lifetime figures and what the bearings really are.
  • Galvanized
    • Mar 2006
    • 468
    Re: About fans and bearings...
    Wow! Lots of info with more to be added. I gave it a slow looking over and saved the link.
    Thank you for the post.
    • Aleksi
      • Aug 2006
      • 20
      Hi Galvanized,
      my pleasure! I'll post here when it's updated in the future.
      • bgavin
        • Jan 2007
        • 1355
        Thanks for the link. I have added that excellent PDF to my reference library.
        • montanaro
          • Sep 2006
          Thanks man,that was one good pdf! It's hard to find bearing and lifetime info.
          I'm using panaflo over my cpu and i almost can't hear it...the only noise i can hear comes
          from my vga cooler, currently dying
          6 successful recaps!!
          • Aleksi
            • Aug 2006
            • 20
            Hi guys,
            it seems she has made progress on the FAQ, part 2 is up.
            http://www.dorothybradbury.co.uk/FAQ.htm
            -Aleksi
            • emil_t
              RTX3090 working fine but fans not spinning
              by emil_t
              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
              04-12-2024, 06:54 AM
            • b-slayer
              Asus Strix-G15-G513RM fans don't work
              by b-slayer
              I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
              The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
              (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
              (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
              ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
              09-04-2025, 04:58 AM
            • gustaznkr
              Nitro 5 AN517-54-51RQ (LA-L181P) Dead after messing around with bootable bios mod!
              by gustaznkr
              Hey guys! I've recently found out this amazing forum where people talk and discuss about electronics repairs and i'm actually amazed with everything that here's have to offer.
              Oh well, i came here looking for a simple bios file in order to get my main laptop working again, but after a while trying to figure out what the hell was going on, i'm quite concerned that it would be worse than i tought. I was fooling around with Mr. Smokeless's UMAF BIOS mod, looking for a way to enable CSM compatibility and legacy boot on my device.
              Device specs:
              AN517-54-51RQ (LA-L181P)...
              06-09-2024, 08:49 AM
            • retrorepair2
              HP Z820 Workstation 4 beeps (sometimes)
              by retrorepair2
              I've got an issue with my Z820 that I'm having trouble working out the root cause of.
              More often than not it'll turn onand fans will blast for a moment before stopping and I'll get 4 beeps that will repeat forever (at least the power light will keep flashing).
              What I can't understand is sometimes it'll just work and I can use it all day but other times it'll boot then reboot then reboot and 4 beeps for the rest of the day. Sometimes it'll work fine from cold for hours, sometimes it'll do the 4 beeps from cold.
              Another oddity is the fans. Before the 4 beeps...
              09-24-2025, 08:05 AM
            • sda sad
              my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
              by sda sad
              Hope this is the right place, someone can help me.
              My laptop started having a really strange problem....
              When I turn it on the fans start working at a crazy rate and with random breaks...
              They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
              And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
              The model of the computer:
              Xiaomi Notebook Pro X 15 OLED (A30)
              04-23-2024, 09:55 AM
