Xbmc ?
  • ivtec
    • Dec 2008
    • 1967
    Xbmc ?
    Hi guys; i just want to watch live streaming soccer games on line,
    what's the benefits of installing XBMC over just getting streaming soccer site links? thanks and have an Happy New Year.
  • mmartell
    • Oct 2013
    • 3189
    Re: Xbmc ?
    Many benefits. Go to xbmchub dot com and check if you have a compatible device.
    • ivtec
      • Dec 2008
      • 1967
      Re: Xbmc ?
      Thanks mmartell: i just downloaded XBMC just to check it out and i was disappointed
      with the sports streaming apps most of the streams do not open or keep buffering '
      I'm better of with streaming sites links.
      • mmartell
        • Oct 2013
        • 3189
        Re: Xbmc ?
        Ya some addons are dead and some are actively supported. If it's one of the more popular sites the addon is likely still in active development.
        Hmm.. I thought you were referring to subscription based services... the free links are always hit and miss.
        Good luck.
        • ivtec
          • Dec 2008
          • 1967
          Re: Xbmc ?
          Good luck.
          Hi; no subscription here,besides they don't carry the teams i like to watch the Sports i like is Live soccer from Europe special from Portugal and is rights protected by XBMC, that's why it's not easy to watch good games in XBMC cause most the sites getting those games are blocked by XBMC, i bet you they have software to block the piracy.It's like Slingbox use to get free stuff now dishnet bought the Slingbox company and now they control everybody that has one with update software that get those pirate sports sites obsolete.,
          This weak i've been just testing XBMC but i only tryed it to check what Live soccer games and how good they are, as steady video with no buffering and i was disappointed with so much freeze and broken repositories, that i gave up and uninstalled Xbmc. my regular link sites work like a charm.
          • mmartell
            • Oct 2013
            • 3189
            Re: Xbmc ?
            xbmc has no "rights protection" nor does any blocking. Join one of the third party xbmc sites (NOT xbmc.org as they ARE more sensitive to piracy issues) and request a dev make an addon for the websites you are referring to.
            xbmchub dot com and/or xunitytalk dot com are two you can try.
            • ivtec
              • Dec 2008
              • 1967
              Re: Xbmc ?
              Thanks mmarell: i'll give that a try but to tell you the truth i think i can get by with just links
              for my favourite live soccer games, i already tried some thirth party repositorries of addons and i had no luck most of the addon streams are broken or buffering too much,xbmc is good but for other stuff like recording streaming videos movies and so on , but for live events games where there are rights protected it's a no no.
              • howardc64
                Samsung UN55JU650DF network/streaming problem
                by howardc64
                Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                07-09-2025, 12:44 PM
              • survivalbloke
                Xbox Series X - crashing to dashboard shortly after launching games
                by survivalbloke
                Hey all! I've got a XBOX Series X which came in with the complaint of games crashing to the dashboard after launch. I've tested a few games so far. Red Dead Redemption I observed will load up fine and sit on the menu no problem, but once I actually load into the world, it will not complete the load-in, and crash, stating something about an error must be sent to Rockstar, etc.. Truck simulator seemed to work fine. Minecraft loaded up and zoned into a world, but within a few seconds, it too, crashed to the dashboard. Where are the logs stored? What should I check?​
                09-18-2024, 11:54 AM
              • amigo744
                PS5 CFI-1016A DISK shuts down only when playing ps4 games error ce-108262-9
                by amigo744
                Hello there,
                ps5 cfi-1016a disk console
                Problem: ps5 shuts down when playing ps4 games after cold boot with error code ce-108262-9.
                After the shut down the console boots up normal and then the ps4 game functions without a problem.
                ps5 games run allways without any problems after cold boot.
                Thats absolutely curious....
                I have already rebuild database, clean cache and reinstall latest firmware with usb stick in safe mode.
                That doesen´t help
                Furthermore i have opened console and renew liquid metal on gpu.
                This all doesn´t...
                06-19-2023, 05:02 AM
              • paparazzo79
                Alienware 17 R3 freezing in games
                by paparazzo79
                Hi guys.
                I own Alienware 17 r3 6820HK GTX 980M.
                I purchased it recently tried some gaming (Rise of the Tomb Raider, Serious Sam) and after 10-15.min games freeze, but I could hear audio from game.
                Now I am not yet at home, but when it happens I do get separate window error message and will post it later.
                Then again there are moments when I could play for like an hour and no errors.
                From my experience reading about this issue, this means my GPU is dying, correct?
                I installed most recent nVidia drivers.
                Temp of GPU while gaming is max 76 C, but usually around...
                04-19-2024, 12:07 PM
              • marekk
                Samsung QE55Q67RAT no sound and bad picture when streaming
                by marekk
                I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
                I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
                Mainboard is based on pcb BN41-02695A BN94-14007B
                I will appreciate any help
                Many thanks
                Marek...
                05-29-2025, 02:23 AM
