Help me rank these caps for my application
  • Maxxarcade
    • Jul 2006
    • 973
    I am going to be making another parts order at work tomorrow, and I need to replenish my stock of caps. I get all my caps from Digikey, and I know what specs I need, but I would like some opinions on which cap is the best for my application, while still being reasonably cheap.
    They will be used in 24/7 duty, commercial PC based games for PSU's and motherboards which run at a pretty high temperature and are subject to fan failure and blocked vents now and then.
    Here are my picks, in no particular order.
    Chemicon KY
    Chemicon LXY/LXZ
    Panasonic FC
    Panasonic FM
    Any other suggestions? I shyed away from Nichicon because we used to use those a lot, and many of them are going bad too soon. Lately I've been favoring the FM's because they are cheaper (and better) than the FC's for some reason.
    I apologize if this has been discussed before, I guess I'm just tired tonight and feeling a bit lazy when it comes to searching...
  • Fizzycapola
    • Oct 2006
    • 423
    Re: Help me rank these caps for my application
    No Rubycon ZLH ? low esr + endurance according to spec
    Rubycon Rubycon Rubycon
    • Maxxarcade
      • Jul 2006
      • 973
      Can I get those from Digikey? If I could, that would definately be the best bet. Aren't Rubycon's considered to be the top of the line when it comes to electrolytics?
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Non-Aqueous Electrolyte:
        Chemicon LXY - low Z, 8K hours
        Panasonic FC - low Z, 5K hours, better CV product than LXY
        Chemicon LXZ - low Z, 8K hours, better CV product than LXY
        Chemicon KY - lower Z than LXZ, 10K hours
        Panasonic FM - lower Z than FM, 7K hours
        For Nichicon:
        PW series has identical specs to the UCC LXZ series
        HE series has identical specs to the UCC KY series
        I've not heard of any problems with the PW or HE series.
        I have heard that Newark will soon start carrying Rubycon, but I didn't see Rubycon in Newark's online catalog.
        PeteS in CA
        • bgavin
          • Jan 2007
          • 1355
          I'm finding that availability is the determining factor for cap selection. After that are the physical dimensions.
          As a USA buyer, the only source I have found so for for Rubycon is Wai Fong in Hong Kong. They are very reliable and fast shipping... but their selection is VERY limited. If Newark carries the Rubycon line, that would be great.. depending upon pricing.
          I am still assembling a huge spread sheet that encompasses all the premium caps, and names all the bad ones. It is far from complete, but quite useful. Thanks to everyone on this board for the huge amount of useful information.
          www.compudox.com/reference
          • Maxxarcade
            • Jul 2006
            • 973
            Forgive me for being dumb, but what does CV stand for?
            • gonzo0815
              • Feb 2006
              • 1600
              Aren`t thePanasonic FM waterbased?
              Any way, i would use the series with longest endurance, but Panasonic Fm is probably the cheapest selection from this list.
              I do not have lontgime experience with the FM`s, but from my point of view you can`t go wrong with them.
              Panasonic hase IMHO proved that they can do very good caps, and even if i consider Rubycon as one of the absolut best brands capwise, i think the difference are negligible.
              But shure, the smaller diameter FM caps are only 2000 to 3000h 105°c, so if yu aren`t always far from that temperature, i would use one of the long endurance series at least for the smaler ones.
              Just to be shure ;-)
              Otherwise you can calculate the lifespann of the caps, if you can estimate the worst case ambient temperature (doubling the rated endurance 105°c by any 10°c below 105°c).
              If the Pansonic FM still fits your endurance requirement, then you can for shure use them.
              CV, i assume this means that this series is smaller compared with others. But not shure about that.
              • PeteS in CA
                • Aug 2005
                • 3581
                Sorry, I forgot to edit what I copy-and-pasted. FMs and KYs are both aqueous series, as is HE.
                CV product (C x V) - poor shorthand on my part. What I'm trying to express is that for a given can size and voltage, the LXZ series usually has a higher capacitance than the LXY series. For example, in a 16mm x 25mm can at 35V, the LXY part is 1200uF, while the LXZ part is 1800uF.
                PeteS in CA
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
                • black6host
                  Replacement caps for Samson Resolv studio monitor 65A Amp board.
                  by black6host
                  Good day!
                  I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                  I'm going to replace the caps and I'll be the first...
                  02-06-2024, 08:22 PM
