out with the old...in with the new.
  • pentium
    • Mar 2006
    • 2778
    My limited workspace means that one of my systems need to be put away in order to fit my new Quadra 700.
    My Epson equity II is being pavked but I have always had a fear with MFM drives. It seems that if the computers cmos loses power, the drive info is lost and when the system tries to boot, it can't because it has forgotten all file attributes. This system however tips this theory upside down with it's design.
    Made in the mid-eighties, it uses an ATX (yes, it it can be turned off in dos command) power supply and has a battery made up of two apple batteries (those batteries are expensive too!). The system has been without the battery and without power before and yet it never loses the drive attributes.
    Is it safe to say that if I pack the system away for say two years, the next time it turns on it will remember how to boot?
    Find Nedry!
    Check the Vending machines!!
  • pentium
    • Mar 2006
    • 2778
    Re: out with the old...in with the new.
    Then I guess it's safe to assume that it will be fine the next time I need it.
    Find Nedry!
    • carrzkiss
      Cyberpower cps1500avr not charging batteries
      by carrzkiss
      Hello, all.
      Cyberpower Battery Backup Unit.
      I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
      When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
      In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
      Checking the voltage, it was down to 22v.
      I quickly removed everything...
      06-15-2024, 02:10 PM
    • howardc64
      Where do repair shops buy MB replacement batteries?
      by howardc64
      Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
      Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
      BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
      07-25-2024, 10:42 AM
    • Astonished
      Fixing the Charge Circuit of the Batteries of the DC Motor
      by Astonished
      Hi friends of electronics
      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
      Please help me fix this circuit.
      (the datasheet of the IC: https://pdf.datasheet.live/28...
      01-28-2025, 06:24 AM
    • dbuergi
      DIY: Modified smart charger for all types of batteries
      by dbuergi
      sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
      Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
      My first work was to bring my Samsung watch battery back to life with was not recognized...
      07-18-2025, 03:17 AM
    • davidebaldini
      UPS ruins batteries every three months
      by davidebaldini
      Problem description:
      My UPS requires new batteries every ~3 months; in this time frame, an average of about 5 to 10 power flickers or short power interruptions (< 2 minutes) occur. After an average of 3 months, a new pair of batteries begins to fail to keep the UPS up during any flicker or power interruption. The load it powers is a single computer/workstation running 24/7 with a continuous consumption between 200W to 300W.
      UPS model:
      The Atlantis 1001 is a non-inexpensive (~120€ back then) home/office offline UPS, rated 1000VA, 600W, designed for two 7Ah...
      10-02-2019, 06:19 AM
