its a device which supplies external voltage to ram for overclocking purposes..
VDimm up to 4.2volts for DDRI
VTT control up to 2.1volts
VDimm up to 3volts for DDRII
125 Watts (160 Watts Peak) power output under load provided for your memory system
55 watts power output under load for VTT
Voltage stability of ±2mV to ±5mV (0.002V – 0.005V) under FULL LOAD
Overload, overvoltage and overheat protection
not something i would buy personally but the reason i am interested is because it is designed by a Greek company. costs 159 euro here.
http://www.hipro-tech.com/products.html
http://forums.techpowerup.com/showthread.php?t=15804
- Filtering this voltage in a way that is close to perfection, by using ceramic capacitors for the RF (Radio Frequency) and large electrolytic capacitors and coils for the voltage spikes and the various fluctuations.
hope they did not use crap caps!
looks like there is not 1 version for all ram but instead different versions of the unit for DDR, DDR2 and DDR3 respectively. but they will also offer upgrade pcbs at low cost.
