26 M pin on a 1155 cpu socket
  • hairykiore
    • Mar 2012
    • 83
    • New Zealand
    Hi..I have downloaded 1155 socket spec sheets but cannot find one that has the pin info in it like it does on one 1156 data sheet...I wonder if anybody knows where I can download one...
    Or
    Pin 26 M ...I want to know what its for so is there any other way to find out other than a data sheet... Thanks hk
  • hairykiore
    • Mar 2012
    • 83
    • New Zealand
    Re: 26 M pin on a 1155 cpu socket
    Hi..I think I have found the sheets I require...Hk
    • withalligators
      Looking for best replacements for Capxons, but can't find data sheets
      by withalligators
      Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
      1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
      1 x Capxon 1000uf35v...
      03-25-2022, 02:30 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • DynaxSC
      ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
      by DynaxSC
      I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
      Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
      Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
      The behaviour is also really very strange, i.e.:
      • The disk shows always up in BIOS - so it is recognized, so far so good
      • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
      02-23-2025, 01:33 PM
    • Isabella91
      Possible to convert eMMC Socket to a micro SD Card socket?
      by Isabella91
      I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
      Read/Write a Micro SD Card from an eMMC Socket.
      I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
      Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
      Not to remove...
      01-14-2024, 05:10 PM
    • warsztat
      Acer AN515-57-577G JDIMM1 socket not working.
      by warsztat
      Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
      11-18-2024, 09:13 AM
