Yo my IDE cable did not work.
  • Fast Alpha
    • Feb 2013
    • 245
    • United Kingdom
    Re: Yo my IDE cable did not work.
    Okay this is the capacitor statistics.
    A lot of them on the board are Teapo
    7x TEAPO 30mm in height/ 10mm width. ( 2700uF, 6.3v, sm 105c ) 12/01 A3
    3x TEAPO 25mm in height/ 5mm width ( 2700uF, 6.3v, sm 105c ) 12/01 A3
    8x TEAPO 20mm in height/ 8mm width ( 2700uF, 6.3v, sm 105c ) 12/01 A3
    1x TayeH 13mm in height/ 6mm width ( 330uF, 6.3v, sm ) A135
    I Couldn't see TayeH temp
    3x brown 20mm in height/ 6mm width ( 1800uF, 6.3v, sm 105c )
    http://www.hse.gov.uk/pubns/indg305.pdf
    • mariushm
      • May 2011
      • 3799
      brown is kzg : 1800/6.3uf
      1800 uF 6.3v 8x20 0.021 ohm 1,870 ma
      These will work from Farnell (since you're in UK I use this site):
      http://uk.farnell.com/nichicon/uhn0j...ial/dp/2112862
      There's a problem with what you wrote: the Teapo can't all be 2700uF 6.3v and have various sizes.
      Teapo SM series datasheet:
      2700uF 6.3v :
      size ripple impedance/esr
      10x19 1450 0.024
      10x25 2200 0.022
      So it's probably the 10x25 version.
      In this case you can go for this:
      http://uk.farnell.com/panasonic/eeuf...0uf/dp/1800611
      There's NO capacitor in the SM series with 5mm diameter. Have a second look and get the right values.
      There's no 2700uF in 8mm diameter. You probably mean:
      1200uF 6.3v 8x20 1250 0.041 (unlikely)
      680uF 8x20 1250 0.041 (possible, but still unlikely)
      Get back to me and the others with some real readings, we don't have to waste our time if you're not serious about it.
      • Fast Alpha
        • Feb 2013
        • 245
        • United Kingdom
        3x TEAPO 25mm in height/ 8mm width ( 2700uF, 6.3v, sm 105c ) 12/01 A3
        8x TEAPO 20mm in height/ 8mm width ( 1000uF, 6.3v, sm 105c ) 12/01 A3
        1x TayeH 13mm in height/ 8mm width ( 330uF, 6.3v, sm ) A135
        fixed.
        • mariushm
          • May 2011
          • 3799
          Well, as I shown above, the SM series shows only two possible types of 2700uF/6.3v :
          10 x 19 mm and 10 x 25mm
          Maybe you're measuring them from the base of the pcb and the capacitors bottoms are swollen?
          You're not really challenged vertically, so the height doesn't matter that much. What is important is the diameter.
          If you can fit a 10mm capacitor where you think you have 8mm capacitors, then you can go ahead and order 10 pieces of that Panasonic FR and you're all set.
          That Tayeh is probably a Teapo - I for one don't have any datasheets for Tayeh. Either way, it's not a critical capacitor imho, so you will be OK with any capacitor that's 330uF 6.3v or 10v:
          http://uk.farnell.com/panasonic/eeuf...-3v/dp/1219445
          http://uk.farnell.com/panasonic/eeuf...0uf/dp/1848405
          http://uk.farnell.com/rubycon/10zlj3...0uf/dp/1831266
          any of the above will work.
          The links above in my previous comment are still valid.
          So you have about 10 uk pounds worth of capacitors. Farnell may require a minimum of 20 pounds for an order in which case.. tough.
          See if rs-components.com has the same capacitors I listed and what their policy is.
          • Fast Alpha
            • Feb 2013
            • 245
            • United Kingdom
            I want to know how to measure correctly.
            Maybe I got it wrong but your trying to get me to go blind with no help what so ever.
            I don't think this is a good forum, for beginners to visit.
            How do you measure
            Is a good iron http://www.maplin.co.uk/30w-solderin...-powered-32909.
            • mariushm
              • May 2011
              • 3799
              #26
              You measure the diameter of ANYTHING ROUND by going through the center of that thing. You don't put the tape by the capacitor trying to guess the diameter.
              You measure the height from the bottom of the metallic can to the top of the metallic can. You don't include the metal tip of that measuring tape, and you don't include the pcb board or the rubber at the bottom of the capacitor.
              People that have to measure diameters and heights usually use calipers, and it doesn't hurt to have something like that around the house anyway, especially since they cost as low as 2-3$.
              I have to disagree and say this is a good forum, provided the people asking questions PAY ATTENTION to what others spending their spare time to help for free ask of them, and are careful to give good answers.
              That soldering iron is crap.
              Ideally, you need a soldering station, which allows you to adjust temperature. Well, the fact that you can adjust temperature is not really that important, it's more important that such stations are more powerful (usually they are 60-75 watts while that iron you linked to is only 30w at best) and can keep the tip of the iron hot. With that small iron, when you put it on the motherboard, the copper in the motherboard will almost instantly cool it down so you'll have to wait some time to get back to the proper temperature.
              If you only need an iron to fix this motherboard, then it will be OK though you'll still have a hard time replacing the capacitors.
              If you plan to do this several times, get a proper soldering station with temperature control.
              As long as you're gonna buy capacitors, you could very well get a soldering iron from the same place, to get the order over 20 pounds or whatever's minimum on Farnell.
              They have better quality irons than Maplin.
              http://uk.farnell.com/duratool/d0079...lug/dp/1568160 if you want cheap.
              If you want something good that will last, this will work:
              http://uk.farnell.com/tenma/21-10115...-uk/dp/2064549
              • Fast Alpha
                • Feb 2013
                • 245
                • United Kingdom
                #27
                Is this a good caliper.
                I will get the solder station. Don't want to overheat anything.
                Give me some links on how to use one.
                I used the 30watt soldering on on a Playstation controller.
                When the dual shock lead came out, I soldered the lead back in the socket.
                Easy.
                So when I get a Caliper, any tutorails on how to measure with it.
                Also that 11 year old did his Dad give him the tools needed for the job.
                • mariushm
                  • May 2011
                  • 3799
                  #28
                  Yes, that caliper is good, but you might find on amazon uk digital calipers that are much cheaper. The accuracy on a digital caliper is good enough, at 0.1mm - the classic ones like the one you linked to can have better accuracy, but they're harder to read and in time the text can wear off.
                  example http://www.amazon.co.uk/Toolzone-Ele...3466334&sr=1-2
                  http://www.amazon.co.uk/s/ref=sr_st?...ers&sort=price
                  Farnell also has them, but they're a bit more expensive so it's not really worth it: http://uk.farnell.com/duratool/d0037...0mm/dp/1341278
                  Links on how to solder and using a solder station, here you go:
                  http://www.youtube.com/watch?feature...&v=J5Sb21qbpEQ
                  http://www.youtube.com/watch?v=fYz5nIHH0iY
                  • Fast Alpha
                    • Feb 2013
                    • 245
                    • United Kingdom
                    #29
                    • mariushm
                      • May 2011
                      • 3799
                      #30
                      Are you serious?
                      One part of the caliper slides left and right. You spread that part of the caliper so the component you want to measure fits tightly between the two parts of the caliper and you read the value.
                      If you have a digital caliper, you just read the value off the lcd screen.
                      If you get a classic one (not digital), you just count the lines at the bottom.. it's not hard.
                      See
                      http://www.youtube.com/watch?v=xssnKUtYYMo
                      http://www.youtube.com/watch?v=4hlNi0jdoeQ
                      • Fast Alpha
                        • Feb 2013
                        • 245
                        • United Kingdom
                        #31
                        Near the processor to the left 3 are 1800uF 16v.
                        KM133A Pro5.
                        More info.
                        • mariushm
                          • May 2011
                          • 3799
                          #32
                          See post #22... what else can i say.
                          • Fast Alpha
                            • Feb 2013
                            • 245
                            • United Kingdom
                            #33
                            It's easy to do.
                            3x TEAPO 30mm in height/ 10mm width. ( 1800uF, 16v, sm 105c ) 12/01 A3
                            7x TEAPO 25mm in height/ 10mm width ( 2700uF, 6.3v, sm 105c ) 12/01 A3
                            Changed.
                            • mariushm
                              • May 2011
                              • 3799
                              #34
                              I don't know how many times I said it already... don't just copy paste and give me crap data if you want accurate answer.
                              There's no 1800uF 16v capacitor from Teapo in the SM series. There's no such capacitor in the datasheets I have. It's probably some other series but you didn't bother to actually check.
                              The brown ones are NOT sm, they're UCC KZG most likely. Teapo doesn't use the brown color on the outside, so they can't be Teapo SM.
                              And they can't be 6mm wide, they don't make capacitors of such high capacity value at 6mm, the smallest possible is 8mm. The datasheet lists them at 8mm.
                              Please double check what you actually post, before clicking on the reply button next time.
                              Anyway, I'm going to give you what's compatible with those boards
                              any from each section will do
                              1800uf 16v:
                              http://uk.farnell.com/nichicon/uhm1c...ial/dp/2113083
                              2700uF 6.3v :
                              1000uF 6.3v:
                              http://uk.farnell.com/rubycon/10zl10...10v/dp/1144682
                              http://uk.farnell.com/panasonic/eeuf...can/dp/1219456
                              http://uk.farnell.com/panasonic/eeuf...rad/dp/1744870
                              1800uF 6.3v:
                              • Fast Alpha
                                • Feb 2013
                                • 245
                                • United Kingdom
                                #35
                                3x TEAPO 30mm in height/ 10mm width. ( 1800uF, 16v, sm 105c ) 11/01
                                7x TEAPO 27mm in height/ 10mm width ( 2700uF, 6.3v, sm 105c ) 12/01 A3
                                Not 100% sure of 100uF height ???
                                8x TEAPO 13mm in height/ 8mm width ( 1000uF, 6.3v, sm 105c ) 12/01 A3
                                1x TayeH 10mm in height/ 6mm width ( 330uF, 6.3v, sm ) A135
                                Just double checking.
                                3x KZG 20mm in height/ 8mm width ( 1800uF, 6.3v, m 105c )
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                • hollox123
                                  ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                  by hollox123
                                  Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                  1. Laptop keyboard doesn't work
                                  2. The backlight on the laptop keyboard doesn't work
                                  3. The x2 side LEDs (red) on the laptop don't work
                                  The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                  I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                  But I am strongly aiming that it is somehow a BIOS-related problem,...
                                  05-11-2025, 08:05 AM
                                • Patch2
                                  Cable Repair
                                  by Patch2
                                  I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
                                  01-02-2025, 06:04 PM
                                • Tr0ll
                                  by Tr0ll
                                  Original T-con:
                                  First replacement T-con:
                                  10-07-2023, 07:48 PM
                                • conghuyms
                                  I need datasheet cable eDP LCD 30 pin slim pls help me!
                                  by conghuyms
                                  My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
                                  08-22-2025, 11:16 AM
