My drive is beginning to fail me!
  • pentium
    • Mar 2006
    • 2778
    After a good 20 years of operation the 20 mb mfm drive in my epson equity II has begun to fail. I have to get everything off the system but there is a problem.
    My 360k drive is becoming flaky and some dos commands relating to copying, formatting and moving have already been damaged.
    I own an ibm data migration set which connects two computers via parallel port for the purpose of moving data but the disk which holds the program to send data is on 3 1/2" floppy while the receiving program is on a 5 1/4" (pretty much reverse of what I want.) I got a 9600 baud modem but I don't know of any services that can handle a system this old. I do however own a copy of procomm plus.
    OR...
    Can I just pull the drive and it's card and place it in another system and from there move everything onto another drive?
    Find Nedry!
    Check the Vending machines!!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    Re: My drive is beginning to fail me!
    20mb!?? atleast it wouldnt take too long to back it up!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      20 years is pretty good!
      i am wondering if i should trust the newest stuff past a year.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i do this often to save stuff from old cnc and industrial stuff.
        i pull the controller and drive and plant it in my testbed system.use ghost to pull an image if i can or just copy the important files/folders
        • pentium
          • Mar 2006
          • 2778
          The thing is I don't have ghost.
          Try to imagine that I don't have a floppy drive at all.
          Sometimes it works, sometimes it won't
          Find Nedry!
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            I thought this was going to be a thread about Viagra... damn.
            Ludicrous gibs!
            • yanz
              • Nov 2004
              • 910
              i have a conner 20mb hdd that still good to this day!
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                might be tough to find but there are 8 bit isa 1.44 controllers around.
                • pentium
                  • Mar 2006
                  • 2778
                  I have a box of old controllers.
                  Find Nedry!
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    You can download the UBCD, there are some good hdd cpartion copy programs 4free.
                    If it is to big to dl, may be you can get them from their weppages.
                    • pentium
                      • Mar 2006
                      • 2778
                      thanks man.
                      Find Nedry!
                      • Maxxarcade
                        • Jul 2006
                        • 973
                        There is also a dos program called Dolly that works great for sector by sector copies of drives. Not sure if it would work with anything other than IDE though.
                        Not sure if it will help, but can you connect the 5 1/4 floppy drive to a newer PC and put a copy program such as Laplink or Dolly on it?
                        Also, did you try cleaning the heads on the 360K drive?
                        • Maxxarcade
                          • Jul 2006
                          • 973
                          Almost forgot, I've got an Epson Equity 1+ with a bunch of custom hardware in it that was used in a PA/central clock/alarm system rack at a school. It has cables that connect to to a couple rackmount boxes full of optoisolators and stuff. Not sure what it does, but I'd love to find out. All I get when I power it up is a beep and a blinking cursor in the top left corner.
                          Does your Epson have the 5 1/4" floppy that has the spring loaded eject button instead of the older style flip down lever/door? I've never seen that type of mechanism on anything but a 3 1/2" drive.
                          • Rainbow
                            • Aug 2005
                            • 1371
                            I have a 5.25" floppy like that and it's made by Canon, IIRC.
                            You can use serial null-modem cable or parallel laplink cable to transfer the data. Norton Commander can be used to do that.
                            • Maxxarcade
                              • Jul 2006
                              • 973
                              I think the issue was getting some transferring software to the computer with the 360K floppy. The only programs I know of that are small enough to fit in a 360K boot disk are Dolly or Laplink. So basically what needs to be done is, connect the 5 1/4 drive to a newer computer running dos-win98 (XP doesn't support 5 1/4" drives), make a dos boot disk using SYS, copy the program to it, put the drive back in the Epson, and fire it up. There is a program that comes with DOS for transferring files too, but I forgot how to set it up.
                              • Maxxarcade
                                • Jul 2006
                                • 973
                                I think I have an old copy of Laplink Pro somewhere, but I can't upload that can I? I think it is still copyrighted despite being made in the late 80's or so. I think Laplink can install itself on a remote machine over serial or parallel as well.
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  don't worry. I managed to assemble a crude system so I could make new ibm software floppies that work. It took a while but it's fine now.
                                  Find Nedry!
                                  • Sus256
                                    HISENSE 65E7KQ PRO - no boot
                                    by Sus256
                                    Hi all!
                                    HISENSE 65E7KQ PRO
                                    RSAG7.820.13512 - chassis
                                    MT9618BAATAB - cpu
                                    RSAG7.820.12059 - power
                                    HD650Y3U77 - panel
                                    KLM8G1GETF - emmc
                                    Replaced emmc.
                                    Terminal log
                                    UART
                                    AC_ON
                                    E-B
                                    FDE enabled
                                    06-01-2025, 02:11 AM
                                  • federalhouse
                                    **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                    by federalhouse
                                    I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                    **Background:**
                                    I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                    **What I've Tried So Far:**
                                    1. I accessed
                                    08-01-2024, 07:03 PM
                                  • perfm2
                                    HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                                    by perfm2
                                    So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                                    Steps taken in my usual process.
                                    Reset security settings in the BIOS
                                    Ensure existing HD comes up into the OS
                                    Shut down the laptop and disconnected the main battery
                                    Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                                    Replace battery connector and close up the laptop
                                    Insert my USB drive with my Windows 10 image I've...
                                    03-21-2023, 08:45 PM
                                  • reformatt
                                    Intel iMacs, 3rd party SSD failures and Fusion setups
                                    by reformatt
                                    I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                    As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                    So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                    12-18-2024, 10:34 PM
                                    HP ProBook 650 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook 600 Specification for Upgrade or Repair
                                    This specification for the HP ProBook 650 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 650 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                    09-06-2024, 08:50 AM
