Which of these cards is better?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Which of these cards is better?
    Not so bad Very High graphics settings at 1440x900 (native resolution of my monitors not happening apparently) with the highest Draw Distance possible!
    My stick of Celery isn't doing to bad either, 50% usage.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      your stick of celery is sandy bridge, really pretty good
      why do you have this secondary pc when you have that main one?
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        For my friend to use when he comes over. When I've cleaned up my desk I'll take a picture, I think it is quite impressive
        and this is the first Celeron CPU I've ever actually liked. It's now going to be my go-to CPU for low-cost computers I build for people.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          I already built a win7 g540 for a friend and yeah it runs win7 pretty good, not super but pretty good. Its sandy bridge, thats why. Very efficient dual core @ 2.5ghz. Add some DDR3-1600 (I do this so the SPD of the DDR3 will put it down to cas 7 cause it will only run it at 1333)...where most normal ddr3 1333 is already currently cas 9
          • derradji89
            Need help Lenovo MIX 320-10lCR domaine name SERCOL
            by derradji89
            Hi everyone 🤗
            I have a Lenovo MIX 320-10lCR computer.**
            1. **Operating System**: Windows 10 ** Education** 64-bit.
            2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
            3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
            4. **BIOS Chip Reflashing**: Currently,...
            04-19-2025, 03:04 PM
          • wrobbie
            Lenovo T14 (AMD, gen1) over-voltage protection IC keeps dying.
            by wrobbie
            My T14's (NM-C801) main USBC input keeps failing every few months. Initially, it worked fine for several years. The symptom is that once powered from the main USBC port using a 65W power brick, after some time (minutes, hours) charging will fail completely. Powering from the secondary (docking) USBC input still works. This laptop is basically always plugged in. The first time it happened, it took me a long time to find that the FPF2281 over-voltage IC for that USBC input was at fault. When the issue occurs, it will continuously reset power delivery negotiations with the power brick -- according...
            02-26-2025, 10:02 PM
            New project for a Lipo4 based battery pack for a battery backup that I found an enclosure from Battery Hookup
            by sam_sam_sam
            Right now Battery Hookup has these e-bike battery packs that are used but I am going to remove them and test them and see how good they are and maybe resell or reused them for another project this is for another day
            When I get the rack mounted enclosure that I mentioned in another post I will see how well they fit in the enclosure and how much room I will have left
            https://batteryhookup.com/products/3...ttery-with-bms
            These battery packs are a little bit hard to get out of the enclosure because they were a little bit glue...
            09-15-2024, 12:17 PM
            SHUTTLE XS 3600BA D2700 Specification for Upgrade or Repair
            This specification for the SHUTTLE XS 3600BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XS 3600BA boardview and XS 3600BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE XS 3600BA...
            09-12-2024, 03:44 PM
          • kokodin
            memory mod for amd radeon r7 260x
            by kokodin
            Hello, for almost a year i been trying to make something that seems impossible, or my testing software is lying to me and it works only i can't see that.
            I been trying to mod a memory on radeon hd7790 or 260x from 2 to 4 gb, but it doesn't seems to be as simple as i first thought.
            In theory 2 workstation graphic cards using the same graphical processor have 4gb of memory firepro w4300 has 4 256x32b layout and W5100 has 8x 128x16b layout all use gddr5 memory and internals of the bioses seems to be very similar so i was trying to wing it , but so far it seems either tserver can't show...
            03-28-2024, 03:48 PM
