AMD 7900 XTX VDD_MEM short
  • karoliens
    • 18
    • Denmark
    I am working on AMD 7900 XTX board that initially had faulty E, F, G, H memory channels (near PCIE). Board is also bent.
    I have reused G and H modules and put new E and F modules. Now no failed channels are detected, but I measure VDD_MEM - 0.4 Ohm to GND.
    Other measurements are as follow:
    VDD_SOC - 0.7 Ohm VDDCR_GFX - 0.3 Ohm VDDCR_USR - 4.4 Ohm VDD_MEM - 0.4 Ohm VDDCI_MEM - 11.3 Ohm 1.8V_S5 - 379 kOhm 0.75V - 48 Ohm 12V_BUS - 4.4 kOhm 3.3V_BUS - 1.3 kOhm
    I guess it is either dead core or something else is shorted on the VDD_MEM line.
    Would you inject voltage to VDD_MEM and see what is getting hot or remove two inductors and check on which side thw short is first?
    Board did not have any previous repair, was still with warranty sticker on the screw except as mentioned is bent I guess due to a sag.
  • lezsimply
    The Wanderer
    • 674
    • Philippines
    • Fixing Computers
    I had almost the same issue like you but on a different card, a 6600xt. I tested all coils and ended up on vddm. I took the risk and injected voltage on the coil. Found out both memory and gpu core is heating up all at the same time. I did not proceed further as I know most of the time it is the core.
    • mayurikid
      • Feb 2026
      • Deutschland
      I have a 7900xtx reference with a Communication error that lets the IC that holds the driver not communicate with the CPU. so the GPU gets suspended and the fans ramp up to safeguard the gpu.
      Failed to get fan speed.
      TransferTableSmu2Dram?
      smu cmn reg print error
      • Laojiu
        • May 2026
        • 中国
        7900xtx The core is really fragile
        • ryancog
          Lenovo Legion 5 Pro 16ARH7H Short On "5V Always-On" Rail
          by ryancog
          Hello there,
          I've got a Lenovo Legion 5 Pro 16ARH7H (AMD Ryzen 7 6800H, NVIDIA RTX 3070Ti) that seems to have "developed" a short on the 5V "Always-On" rail.
          Background
          I don't have too much in the way of useful information here, I don't think. This laptop has been used for the past few years without any notable issues/incidents. The laptop is often "docked" w/ the AC adapter (Lenovo's rectangle one) connected. A few days ago, I finished up working on things in the evening, and the next morning I found the laptop off w/o any...
          04-20-2026, 10:50 PM
        • giulio93
          MSI GF63 partial charging
          by giulio93
          Hi everyone. I have this laptop that had a exploded dc jack. I remove the short (inside the layers next to the dc jack) drilling it out. I have isolate the area with solder mask, then I solder back a new DC-Jack. Then I connected the power pin of the jack with the motherboard (the track there was no more available). The laptop now can be powerd on and seams to work fine. But it do not.
          The charger current is stuck at 0,3A. The battery voltage is 11,9V ish. Then the letters on the keybord don't work and the trackpad too. The number work.
          So I have this 2-3 problems.
          I plugged...
          06-15-2026, 02:13 PM
        • DynaxSC
          Extreme High Current & Low Voltage Short Killer ??
          by DynaxSC
          Hi Folks
          I'm looking for a extreme high current short killer solution for a reasonable cost.
          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
          After taking off the socket, the shorts dissappear again.
          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
          10-15-2024, 10:13 AM
        • blazie151
          Intel NUC, completely lost, short after a simple CMOS battery removal
          by blazie151
          My buddy's fiancé was told to just keep her equipment after switching jobs, which included 2 nice Dell monitors and an i7 NUC (NUC11PAH aka RNUC11PAHi70Z00) with a bios lock. Seeing that there was a CMOS battery cable, I unplugged it, waited a few minutes, then plugged it back in. After that, I got a green stand-by light, and the power button did nothing. So, I tried hooking up to the bios with a CH341A (black version with 3.3v mod) and could not read it at all. In every program except IMSProg, it showed chip not detected, and in IMSProg, it showed up as a completely wrong chip (which happens...
          03-29-2026, 04:06 PM
        • Boardview and Schematic Bot
          AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
          The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm²...
          10-01-2024, 12:20 PM
