LINUX op
  • mariushm
    • May 2011
    • 3799
    Re: LINUX op
    The usb foot pedal appears to the operating system like a keyboard. Imagine a keyboard with all but one key covered and unusable.
    The switch stores inside itself the key it sends to the operating system when you press it.
    By default when you buy it, it comes with one key, maybe the Enter key.
    If you want to change the key, let's say to press Space when you tap the switch with your foot, they only give you a Windows application to do that.
    So every time you want to change the key that's sent by the foot pedal to the computer, you need to run that application in Windows.
    You can install Windows inside Linux using an emulator like Virtualbox: https://www.virtualbox.org/
    Simply run Virtualbox in linux, install a Windows inside it and then inside the emulator, you can say choose that whatever is connected to a usb jack in your computer will also appear inside the emulated Windows.
    So you can run the application inside Windows, set the key, turn off Windows and the emulator and continue working in Linux Mint or whatever you use.
    Wine may also work, but I don't have experience with it.
    • ivtec
      • Dec 2008
      • 1967
      Re: LINUX op
      Thanks but i installed linux cause i did not want to spend money on any win software, i just want this pc to be able to load pdfs and that i could achive,now if i cant flip the page with this pedal thats not good, why does it say linux compatble.
      • mariushm
        • May 2011
        • 3799
        Re: LINUX op
        Why does it say Linux compatible? Because it is Linux compatible.
        If you buy it and connect it directly to linux, every time you press it a key will be detected by the Linux OS and whatever application is active.
        So it works, it does what it has to do. It's your job then to configure the software to change pages whenever that key is detected, if the software doesn't use the same key.
        However, if the software doesn't let you change the key, you CAN change the key that's preset in the foot pedal but only with the Windows software.
        For example, the foot pedal may sent ENTER every time you press it. The pdf viewer expects to receive space to turn pages. You press the foot pedal to turn pages and the foot pedal works, the key is sent, but the pdf viewer doesn't know what to do with ENTER key, because it only turns pages when SPACE is received.
        So you have two options, either make the software change its SPACE key to ENTER, or change the key that the pedal sends from ENTER to SPACE. But the company provides you only with a Windows application to do the later.
        It is Linux compatible, it will be detected by Linux, it would be functional, every time you press on it a key will be triggered and that will show up in Linux. But if you want to change the existing key, you need Windows or make your own Linux application to change the key.
        • ivtec
          • Dec 2008
          • 1967
          Re: LINUX op
          thanks Bro. all i want to use page up page down
          • ivtec
            • Dec 2008
            • 1967
            Re: LINUX op
            Hi Guys, New Update on foot SW pedal,i have here connected to my other machine a 3 way foot switch pedal that i've been using for a long time it has a win CD software,now i thought of connecting it to the lenovo linux mint based and for my surprise it pages up and down the pages, lucky me i did not order other pedal,what a good day and i-m so happy that i got this free linux mint ops.
            • ivtec
              • Dec 2008
              • 1967
              Re: LINUX op
              Hi guy.Need a Music Notation progam to work with Linux mint, i found this one on the link but it seems i have to dowload pakages of some othe linux distro can you guys shead some light and advise i luke this one.thanks.
              http://www.rosegardenmusic.com/getting/
              • Time2Retire
                • Aug 2012
                • 256
                Re: LINUX op
                Just install it through the Linux Mint Software Manager, or the Synaptic Package Manager. They both will do the same thing, and install the application and all needed dependencies. You should install all of your software this way. You don't need to download anything, as the Manager applications do all this for you.
                • tsavpyn
                  Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                  by tsavpyn
                  Dear all,
                  I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                  Now I have a problem that I am unable to dump my BIOS into bin file.
                  My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                  I searched for FPT but there is no Linux version and none of them work.
                  I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                  I would really appreciate it if anyone...
                  05-28-2024, 11:18 PM
                • mr.malcom
                  HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                  by mr.malcom
                  this is a very strange Problem:
                  Notebook hang instantly on Boot. BIOS is accesable.
                  Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                  Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                  i have tried:
                  - only one RAM Stick, another working RAM, both RAM channel
                  - BIOS Flash to newest Version F.50, BIOS Reset
                  - Memtest86 hang instant at Test 2
                  - HP UEFI Diagnostic wont find...
                  02-26-2022, 05:19 AM
                • Hondaman
                  Japanese language -- Win7 or Linux Mint?
                  by Hondaman
                  I ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
                  Does anyone have experience...
                  09-12-2025, 04:32 AM
                • survivalbloke
                  MS Surface Book 3 - Keyboard works only in UEFI/Linux
                  by survivalbloke
                  This is a very weird issue which I'm having trouble finding a common thread.
                  The keyboard is registering keypresses in either the UEFI, or a live Linux USB environment - I used Ubuntu for testing. The keyboard backlight is lit.
                  The keyboard is registering keypresses in Windows or any Windows-related bootable device. For example, it does not work in Hirens Recue or a Windows 11 bootable installer.
                  When booted to Windows, not only is the keyboard not registering keypresses, but my USB keyboard is not either!
                  USB mouse and integrated trackpad...
                  07-14-2025, 03:17 PM
                • keepread
                  SPD reading/writing under Linux and/or Windows
                  by keepread
                  Where can I find the mysterious 'eeprom' kernel module that some use under Linux to read/write SPD?
                  I installed 'i2c-tools' and got 'decode-dimms' tool under Debian but not under Fedora, but both of them are missing the 'eeprom' module.
                  Also tried the SPD.exe tool from EVGA, which correctly lists all of the DIMM slots but reads zeroes from all of them.
                  Basically I need to dump SPD from some modules that were sold to me as DDR-1866 but are made of DDR-1600 chips, and they do not work. There is no access to RAM clock rate in the BIOS, so I am SOL unless I can rebin...
                  01-20-2025, 08:07 AM
