Main board 661GX-M7 no display
  • alihomee
    • Dec 2012
    • 1584
    • malaysia
    i have a mothed board brand ecs model 661gx-m7.it has no display what component should i check
  • Taxman
    • Nov 2012
    • 45
    Re: Main board 661GX-M7 no display
    It would help if you'd provide details of your system set-up and what steps you've already tried to fix the problem...
    • alihomee
      • Dec 2012
      • 1584
      • malaysia
      brand ecs lga775 socket ddr1 ram
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        pictures help too.
        and details like whether the video is missing or its a no post issue.
        at least its not nvidia death syndrome!
        • alihomee
          • Dec 2012
          • 1584
          • malaysia
          ya it is not a nvidia problem
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            by JDC
            ONN 100012588
            Long answer:
            07-15-2022, 07:39 AM
          • howardc64
            A1312 (27ā€ iMac 2009-2011) A1407 (Thunderbolt Display) A1316 (Cinema Display) Display Black Screen Repair
            by howardc64
            Problem
            08-04-2024, 10:36 PM
