Waterfox now supported by XP64!!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Waterfox now supported by XP64!!
    Originally posted by Topcat
    Just a little trick to waterfox and XP...the last installer of waterfox that works with XP is 16, after that, its all vista and up. If you want to run the latest version of Waterfox on XP, install 16 as normal. Then download the portable of the latest version.... Extract the files, backup your waterfox folder, and then copy the new files from the extracted portable into the waterfox folder. When you start it, it goes through the first-run hocus pocus....and then shazam, latest version of waterfox on XP64 (or in my case, server 2003 x64).
    Been doing that with regular Firefox for XP64... I wonder if there's a way to fool the installer into thinking the OS is newer... Another method would be to extract the installer and modify the file that specifies which OS the contained program is compatible with... So far, I've not had luck with either approach...
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      thats why I use the v16 installer, it works. the installer for 18 works as well, but the program executable does not. After that, using the 'portable' install (files already extracted), simply copypasta to the waterfox directory, and viola!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • lti
        • May 2011
        • 2557
        How much faster is Waterfox? I wonder if it would be worth installing on my laptop.
        • mockingbird
          • Dec 2008
          • 5484
          If you have to use that method then there's no benefit to using it since it is updated so sporadically... If you're using XP64, then download the Firefox X64 Nightly in zip format (link), and extract it to wherever you want it installed (c:\Program Files for example). Upon first run, it will create the necessary profile files for you.
          • JoseptahMythMid
            • Feb 2014
            • US
            Hey man, I wanted to inform you that there is a way of making the newest version of Waterfox to work on XP x64. It's so easy, I didn't belive it myself. All you have to do is use 7zip to open the archive of the installer; once you do that then copy the core files onto your desktop.
            To be frank, Waterfox is still fully compatible with XP x64 and runs like a champ; Microsoft is doing it's best to dicourage suppliers from allowing access to many new software. Yet, this is only skin deep, they only create a checking system to stop users from installing Waterfox directly; although it is still designed and has the original coding ( Yet updated) to run on XP x64.
            So, Good luck to you; and all I ask is that you spread the word of this discovery. Let those faithful to XP x64 know of this discovery as I have to you. Thank you for your time and I hope this is helpful to you.
            • JoseptahMythMid
              • Feb 2014
              • US
              #26
              I suppose you aslready know this Topcat... I had replied to an older post by you; although, anything related to XP x64 I am honored to help out in some way. I am glad to see those who still love XP x64 and understand it's power and usefulness even in this age 2014. As the future progrsses it will be harder to combat software venders who refuse to allow access but, that shall also change, for a new age is coming; one full of indipendent thinkers, inventers, coders, hackers, ect. I shall be among them... I do hope you and others may join me but, if not that is fine for each effort made by me alone shall echo and grow larger; Imagine if thousands and millions joined this new movement? It would be wonderous! Anywho, thank you for all the useful info here Topcat and everyone else here.
              • ahmedtou
                HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                by ahmedtou
                help me please
                I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                I will share all the details with you, including the disc information.
                Code:
                HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                Current Profile: BD-R
                Disc Information:
                Status: Empty
                State of Last Session: Empty
                Erasable: No
                Free Sectors: 12,219,392
                Free Space: 25,025,314,816 bytes
                Free Time: 2715:27:17 (MM:SS:FF)
                Next
                08-27-2025, 08:49 AM
              • pwingman
                HP ZBook Firefly 14(G8) (PASS)(UNLOCK)
                by pwingman
                I forgot the password of the admin settings do I need to dump the original bios first?
                Code:
                System Information
                    Manufacturer: HP
                    Product Name: HP ZBook Firefly 14 inch G8 Mobile Workstation PC
                    Version:
                    Serial Number: 5CG1070BLR
                    UUID: d996a728-d393-4bfb-a592-ac1f5fda2e7e
                    Wake-up Type: Power Switch
                    SKU Number: 2C9Q1EA#ABH
                    Family: 103C_5336AN HP ZBook
                BIOS Information
                    Vendor: HP
                    Version: T76 Ver. 01.01.32
                    Release Date: 03/26/2021
                09-25-2024, 02:41 AM
              • TPLinux
                HP Zbook 15u G5 and help with eeprogrammer software
                by TPLinux
                administrator_password = enabled
                family = 103C_5336AN HP EliteBook
                sku = 2WK45AV
                uuid = 234a5333-a16f-6ab4-d9f8-52786f714142
                serial: 5CG8346KB2
                Motherboard Manufacturer: HP
                Product Name: 83B2
                Version: KBC Version 04.6E.00
                Serial Number: PGWMB00WBB804M
                BIOS Information
                Vendor: HP
                Version: Q78 Ver. 01.23.00
                Release Date: 11/30/2022
                Address: 0xF0000
                Runtime Size: 64 kB
                ROM Size: 32 MB
                Characteristics:
                PCI is supported
                PC Card (PCMCIA) is supported...
                07-12-2023, 09:43 AM
              • Junior††
                PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                by Junior††
                Good Afternoon fellas,
                Issue:
                Disc is showing as not supported when a disc is put in.
                Here's what I've done, you can skip this if you just wanna know the question:
                - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                - reflowed the disc drive connector
                -reflowed the chip in question (shown on image)
                - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                Question:
                I...
                02-19-2025, 12:48 PM
                FUJITSU ESPRIMO Q556 ESPRIMO Q i3-6100T Specification for Upgrade or Repair
                This specification for the FUJITSU ESPRIMO Q556 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ESPRIMO Q556 boardview and ESPRIMO Q556 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for FUJITSU...
                09-12-2024, 03:44 PM
