Waterfox now supported by XP64!!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    http://www.waterfoxproject.org/
    This was a long time a-coming!!! I was updating waterfox on my win7 laptop and noticed it said XP64 in the supported OS list, I had to re-read it to make sure I read it right!!! ....and sure enough, I downloaded it and checked it on my main rig (X64 of course), and sure enough!! YAY!! This just extended the life of XP64 indefinitely for me, it was the only program I wished for the longest time was supported by X64....and now it is!
    LONG LIVE XP x64!!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Waterfox now supported by XP64!!
    Coincidence! I just installed XP x64 today!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Phaihn
      • Jan 2009
      • 842
      i tried to install it on my laptop yesterday kept telling there was no hard drive.
      My Computer.
      AMD APU A4-3300 2.5ghz 1mb cache
      Motherboard GigaByte GA-A75M-S2V
      Kingston HyperX Blue DDR3 8GB (2x4GB)
      SB Audigy 2 ZS [B800] Sound Card
      500GB WD Caviar® Blue™
      1 Terabyte WD Caviar® Black™
      2 Terabyte WD Caviar® Black™
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Your laptop is probably in AHCI mode and you probably don't have an AHCI driver for your chipset.
        Arc A770 16 GB
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          It's interesting keeping this in mind:
          http://www.techspot.com/news/50887-f...r-windows.html
          But thanks for the recommendation, I installed it, actually the first 64-bit browser I'm using, never started using Opera 64-bit (It's my browser of choice otherwise)
          • mockingbird
            • Dec 2008
            • 5484
            Topcat, can you please force-enable acceleration and run these tests:
            HWACCEL
            GUI Mark 2
            Can you also post your Graphics section of "about:support"?
            To force-enable acceleration, go to about:config and change the following to true:
            1) gfx.direct2d.force-enabled (This one shouldn't do anything, as Direct2D acceleration will never be supported with any iteration of Mozilla in XP, but I'm still curious to see if there's any result)
            2) layers.acceleration.force-enabled
            3) webgl.force-enabled
            Here's what I get with Chromium (Not that I use it, I just wanted to test it):
            Chromium 25.0.1326.0 (Build 167754)
            That version of HWACCEL I posted is limited to 60fps...
            Oh, and does changing gfx.font_rendering.directwrite.enabled have any effect?
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              I will when I get home. The GX745 I'm on right now probably wouldn't be the best to test with, its a pretty weak system.....but it likes waterfox.
              Team : 49813
              Join in!!
              Team Stats
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                My office machine with a crappy GT9600 GPU said 18FPS. I'm wondering how you got 90FPS when it tells you that results are limited to 60FPS....hmmm
                Team : 49813
                Join in!!
                Team Stats
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  My home system said 49FPS with a GTX580. Nice framerates....but I still choose not to run a browser put out by a company that made its fortune spamming the world. I'll stick with my slow Mozilla.....
                  Team : 49813
                  Join in!!
                  Team Stats
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    For me, Firefox works best when you use:
                    Code:
                    nglayout.initialpaint.delay 0
                    and
                    Code:
                    network.http.pipelining true
                    Then general browsing may be faster than all the other browsers!
                    The default delay is pointless for today's internet.
                    Arc A770 16 GB
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Chrome is horrible Firefox all the way!
                      IF I were to have to use Chrome (and that's IF) I would use Comodo Dragon.
                      • mockingbird
                        • Dec 2008
                        • 5484
                        The official HWACCEL is limited to 60fps... Someone posted a downloadable version without the limit.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Don't upgrade to version 18.01 or you will get this error:
                          "Waterfox.exe is not a valid Win32 application"
                          https://www.google.se/search?client=...32+application
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            Yup, already found that out. Had to go back to 16.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              thanks. didnt know about this browser. really fast.
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                Awesome, still got an XP 64 machine running. Is Waterfox a lot faster than firefox?
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16958
                                  Just a little trick to waterfox and XP...the last installer of waterfox that works with XP is 16, after that, its all vista and up. If you want to run the latest version of Waterfox on XP, install 16 as normal. Then download the portable of the latest version.... Extract the files, backup your waterfox folder, and then copy the new files from the extracted portable into the waterfox folder. When you start it, it goes through the first-run hocus pocus....and then shazam, latest version of waterfox on XP64 (or in my case, server 2003 x64).
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    cool!
                                    wonder why they dropped support when it runs fine anyway?
                                    sort of like my friends 2000 box that melted down when the neutral opened last week.
                                    he bought a nice quad core box i had and then found out the really old quickbooks would not install on 7 x64.went to the floppy disks folder and started install from there.
                                    it worked fine.the limitation was in the flashy installer front end only!
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      Originally posted by kc8adu
                                      cool!
                                      It needs to be recompiled with VS 2010 or earlier or change an option that's disabled by default in VS 2012 and later.
                                      With VS 2012 and later, after changing the option, recompile.
                                      Or XP will think it's corrupted! It's actually Windows rejecting it, because it thinks it's a malformed .exe and the like.
                                      Arc A770 16 GB
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16958
                                        only v18 did that. I'm running v26 with the little trickery above, no issues....but the installer won't run on XP.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                        • pwingman
                                          HP ZBook Firefly 14(G8) (PASS)(UNLOCK)
                                          by pwingman
                                          I forgot the password of the admin settings do I need to dump the original bios first?
                                          Code:
                                          System Information
                                              Manufacturer: HP
                                              Product Name: HP ZBook Firefly 14 inch G8 Mobile Workstation PC
                                              Version:
                                              Serial Number: 5CG1070BLR
                                              UUID: d996a728-d393-4bfb-a592-ac1f5fda2e7e
                                              Wake-up Type: Power Switch
                                              SKU Number: 2C9Q1EA#ABH
                                              Family: 103C_5336AN HP ZBook
                                          BIOS Information
                                              Vendor: HP
                                              Version: T76 Ver. 01.01.32
                                              Release Date: 03/26/2021
                                          09-25-2024, 02:41 AM
                                        • TPLinux
                                          HP Zbook 15u G5 and help with eeprogrammer software
                                          by TPLinux
                                          administrator_password = enabled
                                          family = 103C_5336AN HP EliteBook
                                          sku = 2WK45AV
                                          uuid = 234a5333-a16f-6ab4-d9f8-52786f714142
                                          serial: 5CG8346KB2
                                          Motherboard Manufacturer: HP
                                          Product Name: 83B2
                                          Version: KBC Version 04.6E.00
                                          Serial Number: PGWMB00WBB804M
                                          BIOS Information
                                          Vendor: HP
                                          Version: Q78 Ver. 01.23.00
                                          Release Date: 11/30/2022
                                          Address: 0xF0000
                                          Runtime Size: 64 kB
                                          ROM Size: 32 MB
                                          Characteristics:
                                          PCI is supported
                                          PC Card (PCMCIA) is supported...
                                          07-12-2023, 09:43 AM
                                        • Junior††
                                          PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                                          by Junior††
                                          Good Afternoon fellas,
                                          Issue:
                                          Disc is showing as not supported when a disc is put in.
                                          Here's what I've done, you can skip this if you just wanna know the question:
                                          - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                                          - reflowed the disc drive connector
                                          -reflowed the chip in question (shown on image)
                                          - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                                          Question:
                                          I...
                                          02-19-2025, 12:48 PM
                                          FUJITSU ESPRIMO Q556 ESPRIMO Q i3-6100T Specification for Upgrade or Repair
                                          This specification for the FUJITSU ESPRIMO Q556 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ESPRIMO Q556 boardview and ESPRIMO Q556 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for FUJITSU...
                                          09-12-2024, 03:44 PM
