Updated: Apple recalls 1.8 million laptop batteries
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Spencer Chin
    EE Times
    (08/24/2006 2:21 PM EDT)
    MANHASSET, N.Y. - Apple Computer's woes continued Thursday (Aug. 23) with the company recalling 1.8 million Sony-based, rechargeable lithium-ion battery packs for a number of its iBook G4 and PowerBook G4 notebook computers.
    The recall, reported in a release by the U.S. Consumer Product Safety Commission, involves 1.1 million battery packs sold inside the U.S., and 700,000 sold outside the U.S.
    Sony's lithium ion battery problem has grown in scope. I wonder whether there are any more shoes to drop, e.g. Sony Vaio notebooks.
    PeteS in CA
  • arneson
    • Sep 2005
    • 1267
    Re: Updated: Apple recalls 1.8 million laptop batteries
    Report stated metal particle impurities inside cells making cotact with case causing shorts.
    Sonys power division is up the creek already.
    Jim
    • Shroomie
      • Apr 2006
      • 356
      Sony Vaio notebooks
      Given the cost of those, I'd like to see them go down, too...But then, they shouldn't, for that price you should get quality.
      Y'know, around the same price range as Apple notebooks, or higher-range Dells...
      You know there's something wrong when you open up a PSU and are glad to find Teapos.
      Why I don't buy cheap cases!
      • a_p3rson
        Apple Watch Charging Controller Schematics / Boardview - 820-02601
        by a_p3rson
        Hi there,
        I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
        You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
        This daughterboard uses an interesting...
        04-21-2025, 11:41 PM
      • carrzkiss
        Cyberpower cps1500avr not charging batteries
        by carrzkiss
        Hello, all.
        Cyberpower Battery Backup Unit.
        I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
        When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
        In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
        Checking the voltage, it was down to 22v.
        I quickly removed everything...
        06-15-2024, 02:10 PM
      • RWS93
        Apple A1990 / Board number: 820-01041
        by RWS93
        Brand: Apple
        Model: A1990
        Problem: I am not an Apple kind of guy to start with. But I am quite experienced with motherboard repairs in general. So the laptop is stuck with 5v 0.250A and does not negotiate 20v. Same symptom on all 4 USB C ports. When charger is plugged the amps start at around 0.060 then go trough: 0.100 - 0.180 - 0.230 - 0.244 and stay like this. Laptop responds to the power button: once I hold it long enough current goes down to 0.060A and then up to previous levels.
        Board clean, no liquid damage, no corrosion....
        04-11-2024, 03:43 PM
      • howardc64
        Where do repair shops buy MB replacement batteries?
        by howardc64
        Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
        Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
        BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
        07-25-2024, 10:42 AM
      • Astonished
        Fixing the Charge Circuit of the Batteries of the DC Motor
        by Astonished
        Hi friends of electronics
        What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
        The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
        Please help me fix this circuit.
        (the datasheet of the IC: https://pdf.datasheet.live/28...
        01-28-2025, 06:24 AM
