Firmware updates via USB and network
  • japlytic
    • Oct 2005
    • 2086
    When doing a firmware update on a wireless router, it should ONLY be done via a wired connection.
    And with firmware updates via USB, the device should be DIRECTLY connected to the host (PC), not via a USB hub.
    I think a number of update problems (even failures too!) are the result of not doing the above.
  • mariushm
    • May 2011
    • 3799
    Re: Firmware updates via USB and network
    It's not the transfer method, it's the implementation.
    Transfer is just transfer, nothing (but lack of memory or storage space for the new firmware) stops the firmware in the router to do a hash/crc check the determine if the firmware was uploaded correctly... before actually burning it permanently.
    • TheUser
      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
      by TheUser
      Hello to everyone ,
      This is my first post here, and i would like to share with you a small story in case you can help me.
      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
      02-10-2024, 02:07 PM
    • rumpumpel1
      ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
      by rumpumpel1
      Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
      10-24-2024, 08:59 AM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
    • filippia1981
      Starlink WiFi router firmware of the HR1211 IC
      by filippia1981
      Hi, I would like to ask if someone has the firmware of the HR1211 IC of the Starlink WiFi router in order to program a new IC
      The diagnosis showed that this IC is shorted and need to be replaced with the right firmware. I cannot find the firmware
      kind regards
      Ioannis Balouktsis
      06-17-2024, 11:38 AM
    • piernov
      Infineon TPM firmware update files
      by piernov
      Infineon TPM firmware update files:
      Infineon_firmware_update.zip
      Code:
      TPM12_4.32.879.0_to_TPM12_4.34.1010.2.BIN
      TPM12_4.33.949.0_to_TPM12_4.34.1010.2.BIN
      TPM12_4.40.119.0_to_TPM12_4.43.257.0.BIN
      TPM12_4.40.119.0_to_TPM12_4.43.258.0.BIN
      TPM12_4.40.119.0_to_TPM12_4.43.259.0.BIN
      TPM12_4.40.119.0_to_TPM20_5.62.3126.0.BIN
      TPM12_4.40.119.0_to_TPM20_5.63.3144.0.BIN
      TPM12_4.40.119.0_to_TPM20_5.63.3353.0.BIN
      TPM12_4.42.132.0_to_TPM12_4.43.257.0.BIN
      TPM12_4.42.132.0_to_TPM12_4.43.258.0.BIN
      TPM12_4.42.132.0_to_TPM12_4.43.259.0.BIN
      10-25-2025, 10:09 AM
