Re: The hard drive failure thread
Wow that was an old post of mine, must have been my 120G disks for my old RAID... I've since decommissioned that RAID but the drives were still working just fine when I took it apart.
Oh well, I guess it won't hit 100K hours unless I decide to use the disk somewhere else... And I wonder if anyone would take their chances with a 70K POH drive on eBay
I've actually had decent luck with Toshiba disks. The old ones are slower than the "usual brands" but haven't had one fail as I simply haven't had many of them. The other brands I've had failures on pretty much all of them as I've went through more of them.
That being said I wonder if the raw number is actually the wrong endian, wrong bit order, or even if there are sub bit fields in that number. You can't necessarily trust the number in "raw value" because it is manufacturer (and model) specific. The only numbers that you can trust is making sure the VALUE number is greater than THRESH; the only other indication is if VALUE has decreased since it was new. Note that this number for VALUE can go up and down so it's really hard to tell what's the disk lying about... Then again there are a lot of pending reallocates...
Originally posted by Compgeke
View Post
