Bad Rubycon, too?
    Bad Rubycon, too?
    Just found a bulged MCZ in a Dell Dimension 5000... Is this a common occurrence?
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Bad Rubycon, too?
    When overheated, yes. I've seen bulged caps from every brand when used in SFF machines for over 5 years.
    Ludicrous gibs!
      It's a fat tower, and all of the other caps are good. Seems strange; there look to be other caps in parallel, which are ok.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Might have been a defective cap. It happens.
        You have an ESR meter? If so, pull them all and test them just to be sure.
        sigpic
        (Insert witty quote here)
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          I harvest as many bad rubycons these days as KZG's. mostly from USFF systems....but some aren't.... No cap is indestructible, given enough time and heat, the best lytics will spooge...
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
            I'm not allowed to touch any of the systems here with the iron or ESR meter; boss says just leave it, so I will! When it goes bad in a year's time, I can simply say "I warned you..." I also found another Dell (I think Optiplex 280) with a bad Nichicon HM but with 2006 date code - not in the 2001-2004 range for manufacturing defects, so I guess it just went bad on its own too. And a power supply with two bad Fukkyuus.
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              Could it be ripple from the power supply in excess of its specs? If the PSU is failing enough. I often see "MCZ" when I hear of Rubycon failures so it has been noted before that MCZs are sensitive to heat, maybe moreso than other "good" capacitors for whatever reason.
              • larrymoencurly
                • Oct 2004
                • 960
                A guy I know who bought a pickup truck full of Pentium 4 Dells (mostly Optiplex GX270) and spent the weekend recapping them said he was surprised to find so many failed Rubycons next to the heatsink, but they weren't nearly as bad as the Nichicons in the same locations.
                  by momaka
                  03-15-2023, 10:17 PM
                • J_T
                  Operating frequency for motherboard common mode inductor/filter
                  by J_T
                  I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
                  The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
                  Sorry, I am not experienced hence a basic question.
                  01-04-2025, 05:54 AM
                • triplefour
                  JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                  by triplefour
                  got this tv from a friend who got a new one and didnt want to bother repairing this one.
                  he said it sometimes would just flash color patterns.
                  and sometimes it would just work
                  i figured it had some intermittent mainboard issue.
                  i stored it at home for a while before looking at it
                  when i plugged it in for the first time, i heard some popping noises
                  and then a big cloud of white smoke came out of the back of the tv!
                  i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                  i unplugged it and took the back off and discovered...
                  12-18-2022, 12:38 AM
                • Jane
                  HP ProBook 450-G2 LA-B181P - What is a common resistance?
                  by Jane
                  I have faulty HP ProBook 450-G2 LA-B181P - doesnot start. When connecting a charger, the LED on plug in connector blinks from yellow to blue. (I tried to search a short on mainboard.)
                  What is a common resistance ( to ground ) I should measure on a coil that leads to VGA chip(RT8880CGQW) ? I measure only about 9.6 Ohms. Is it normal?
                  03-11-2025, 05:26 AM
                • ctroxtell
                  Carrier HK50AA063 display controller common failure help
                  by ctroxtell
                  I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                  02-05-2025, 05:31 PM
