Epox EP-9NPA Ultra MOSFET
  • Mithras
    • Jul 2006
    • 5
    Hello, I have a Problem with one of my Mosfets on an Epox Board.
    The Problem ist, I brought the board from Ebay, and the Mosfet is more than a little bit damaged.
    I just soldert this thing out, but the problem is I don`t know where to get a replacement part.
    I marked the part on this picture:
    http://www.meister-eck.de/ep.jpg
    This is written on the part:
    K3918
    CG 58 (or maybe CG S8)
    Would be great if you can help me with that.
    Martin
  • Rainbow
    • Aug 2005
    • 1375
    Re: Epox EP-9NPA Ultra MOSFET
    It should be 2SK3918:
    http://www.necel.com/cgi-bin/nesdis/...918&doccode=DS
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      The 2SK3918 is made by NEC, and is a proprietary P/N. If NEC parts aren't readily available to you, you could cross it to parts from IR, Fairchild, or STMicroelectronics. The key parameters are: V(DSS) = 25V; I(Continuous) Max = 48A; R(D-S On) = .0075 ohm max.; and C(iss) = 1300pF. 25 or 30V would suffice; somewhat higher than 48A would be OK; lower than .0075 ohm would be OK; less than 2000pF would probably be OK, lower than 1300pf would be preferred.
      PeteS in CA
      • Tom41
        • Oct 2005
        • 338
        • England
        Slightly off-topic, but what are those things on the motherboard that look like miniature PCI slots? There are three of them near the ATX power connector.
        You know there's something wrong when you open your PC and it has vented Rubycons...
        • Shroomie
          • Apr 2006
          • 356
          Think they're PCI Express x1 slots. That's a PCIe x16 video card slot, so...
          You know there's something wrong when you open up a PSU and are glad to find Teapos.
          Why I don't buy cheap cases!
          • Rainbow
            • Aug 2005
            • 1375
            Yes, useless PCI express slots as there are almost no cards you can put in.
            • Mithras
              • Jul 2006
              • 5
              well, I`ve tried to find the SK3918 nearly everywhere, or something similar, but it looks like that there is no german shop that has this mosfet. Does anyone know a good shop in Europe/Germany that has such Mosfets?
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                sk3918 is a rca sk replacement and likely an entirely different part than you need.
                2sk3918!
                • Mithras
                  • Jul 2006
                  • 5
                  I`m sorry i meant the 2SK3918....
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    Try to look at www.reichelt.de, www.pollin.de or www.segor.de
                    You may find some compatibel devices there.
                    www.rsonline.de will have may be more choice, but a little more expensive.
                    • Mithras
                      • Jul 2006
                      • 5
                      https://cdn.badcaps-static.com/pdfs/...aad62025ae.pdf
                      Thats the best one I could find.. damn...
                      • PeteS in CA
                        • Aug 2005
                        • 3583
                        I received your PM, Mithras, and it looks like the best choice through Digi-Key here in the US would be D-K P/N IRF3709ZS-ND. It's gate capacitance is a bit high, 2130pF. On the other hand, its R(DS On) is lower, so the extra losses from the higher gate capacitance may be balanced by the lower (I^2)(R) loss.
                        PeteS in CA
                        • Mithras
                          • Jul 2006
                          • 5
                          i`ll try this one, thank you man!
                          • PeteS in CA
                            • Aug 2005
                            • 3583
                            Digi-Key doesn't list it, but Fairchild's FDB8870 looks to be close to the original - about the same R(DS On), 1700pF gate capacitance, rated for slightly higher current.
                            PeteS in CA
                            • Rainbow
                              • Aug 2005
                              • 1375
                              As it's not exact replacement, I'd replace all 3 MOSFETs so they will be the same.
                              • PeteS in CA
                                • Aug 2005
                                • 3583
                                Good point, Rainbow. In PMs I suggested several other parts, two from STMicro and two from Infineon. I wasn't aware, when I posted above, that Mithras is from Germany. STMicro and Infineon might be more available to him than IR (OTOH, he has a contact in the US, hence the D-K//IR recommendation above).
                                If anyone is curious, I could post the STMicro and Infineon P/Ns I suggested in the PMs.
                                PeteS in CA
                                • Jane
                                  How do you test MOSFET in laptops ?
                                  by Jane
                                  I tried to use this method:
                                  Testing an N-channel MOSFET:
                                  Step 1: Discharge the Gate (turn off the MOSFET)
                                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                  Step 2: Charge the Gate (turn on the MOSFET)
                                  Now, place the red probe on the Gate (G) and the black probe on the
                                  09-27-2024, 03:31 AM
                                  LG Gram Ultra-Lightweight Notebook Specification for Upgrade or Repair
                                  This specification for the LG Gram Ultra-Lightweight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Lightweight boardview and Ultra-Lightweight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 03:40 AM
                                • Nooy
                                  VGA MOSfet permanently shorted and loss of MOSfet pad
                                  by Nooy
                                  Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                  I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                  02-14-2024, 02:26 AM
