Greetings! Is broken flash drive can be fixed? because I found a flash drive in our house but when I plug it in it says the device driver was not successfully installed.
Flash Drive Question.
Re: I have a question.
Usually not. Is this a generic drive or is there an actual brand?sigpic
(Insert witty quote here) -
Re: Flash Drive Question.
Open it up and see if theres any broken-off smd parts, or anything else suspicious. I once literally saw one of the two memory chips partially off. Resulting in a 'drive not formatted' cause the first memory chip had the mft an most of the data. Was never able to get it fixed, too smallCap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
I have a very old USB flash drive that shows that message in Vista when inserted, but it still works perfectly well.________________________________________________
Invisible airwaves crackle with lifeBright antennae bristle with the energy________________________________________________Comment
In some, the weak point is the soldering of the USB connector to the circuit board.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
Good evening,
I need help with dissassembling my USB Flash Drive (ADATA C008 / 16GB), the problem is that I don't know how to approach this USB Flash Drive dissassembly without damaging the USB Flash Drive itself....-
11-10-2024, 10:55 AM -
by ekozeko333Hi all,
I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
🔥 The Problem Started After Suspected ESD/PD Fault
I experienced a power issue or ESD event through a USB-C charger
After that, the NX20P5090 power switch was visibly burned and was replaced
Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
🧠 What I’ve Done So Far
Flashed...-
Channel: BIOS Requests ONLY!
by perfm2So I've worked on dozens of HP and Dell laptops and have never encountered this before.
Steps taken in my usual process.
Reset security settings in the BIOS
Ensure existing HD comes up into the OS
Shut down the laptop and disconnected the main battery
Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
Replace battery connector and close up the laptop
Insert my USB drive with my Windows 10 image I've... -
by corrizeHello, I'm stuck in troubleshooting…
The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
When I press the flash button, it's detected by the system, flash icon appear on LDC display.... -
This specification for the HP EliteBook x360 1030 G3 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 1030 G3 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...09-06-2024, 08:50 AM
- Loading...
