Flash Drive Question.
  • rhaivhen
    • May 2012
    • 12
    • Philippines
    Greetings! Is broken flash drive can be fixed? because I found a flash drive in our house but when I plug it in it says the device driver was not successfully installed.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: I have a question.
    Usually not. Is this a generic drive or is there an actual brand?
    sigpic
    (Insert witty quote here)
    • rhaivhen
      • May 2012
      • 12
      • Philippines
      Re: Flash Drive Question.
      if i can remember. this is a transcend 2gb.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5043
        • US
        Open it up and see if theres any broken-off smd parts, or anything else suspicious. I once literally saw one of the two memory chips partially off. Resulting in a 'drive not formatted' cause the first memory chip had the mft an most of the data. Was never able to get it fixed, too small
        • Radio Fox
          • Jan 2010
          • 281
          Despite that message, is the device still recognised by the OS?
          I have a very old USB flash drive that shows that message in Vista when inserted, but it still works perfectly well.
          ________________________________________________
          Invisible airwaves crackle with life
          Bright antennae bristle with the energy
          • shadow
            • Feb 2007
            • 732
            This message has appeared several times for me over the years. Usually reinserting it fixed it. Have no idea why the message came up to start with.
            • japlytic
              • Oct 2005
              • 2086
              In some, the weak point is the soldering of the USB connector to the circuit board.
              • 999999999
                • Sep 2006
                • 774
                Try it on a different computer, could be an OS issue or dirty USB socket contacts. I once had a hub I almost tossed out when all it needed was a bath.
