Gigabyte s478 mobo hangs on initializing USB devices during post
  • Koda
    • Aug 2011
    • 317
    • Macedonia
    Ok so I'm redoing the post in this section because I wasn't getting anywhere in the motherboards section. Here it is:
    So I got this Gigabyte s478 for free, too lazy atm to check what model it is, and when I tried to start it wouldn't boot at all so I used the hairdryer trick to heat up the capacitors to see if it'll start (all OST and a few KZG's none bulging) and it did boot but only to the point of initializing USB devices. I'm thinking of recapping the whole mobo with salvaged caps from other mobos but don't know if it's worth the effort. Could this problem be caused by the OST caps that are obviously failing or could it be the the USB controller IC and will removing it allow the motherboard to boot normally? Also when I plug in the 20pin PSU connector or the power cord to the PSU the fans on the mobo briefly start turning and after about a second they stop. The mobo has a VIA chipset I think... I'll have to check what mobo it is tomorrow, getting late here. Pic's coming up in next post. Also to add caps were in reverse polarity, I thought that applied to ASUS boards only but Gigabyte...? Good thing I caught it in time and I got the pics to prove it!
    Guns don't solve problems. I'll take 12
    master hoarder
    • May 2008
    • 12175
    Re: Gigabyte s478 mobo hangs on initializing USB devices during post
    Based on your findings, I would say it's the Ost and KZG caps that are messing it up. If that doesn't fix it, it could also be a bad BGA joint on the Northbridge or Southbridge. Given that this is a desktop board, bad caps are *a lot* more likely to be your problem.
    As far as whether it's worth to save it by scavenging caps from other boards - that depends if you want to and have the time to do it.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      just scavage things that are good caps, sanyo, ruby, etc, etc. nothing too old ether
      • Koda
        • Aug 2011
        • 317
        • Macedonia
        Yeah, that's pretty much what I figured although this is a non ROHS board that most likely uses leaded solder for BGA's so a BGA problem is highly unlikely. Also is the USB controller on p4 boards integrated in to the chipset or is it a standalone IC?
        Anyway I'm gonna go ahead and waste 2 hours of my time to try and save this mobo to use it for a backup troubleshooting system. I'm going with salvaged Rubies all the way on this one, MBZ for the vrm (6x6.3 3300uf and 4x16v 1500uf)and YXG for the rest of the board (22 x 16v 1000uf and 6 x 25v 100uf). If it turns out to be BGA problem I'll just reflow both SB and NB and see what happens. IMO its worth saving every piece of hardware, even if it is archaic.
        • Koda
          • Aug 2011
          • 317
          • Macedonia
          So I did it. I recapped the damn thing. Redid the whole board, even the small 100uf ones. Fired it up, and it loaded windows live cd perfectly twice. Turned it off and left it sitting for a while and after coming back and turning it on for a 3rd time.... "initializing usb controller... " and the damn thing did it again. Reflowed the SB/NB but still no luck. Not a cap problem, not BGA, what could it be?????
          • Hexel
            Asus K513E mobo X513EA R5.4 hangs during OS load, item partno needed
            by Hexel
            Hello!
            I need help identifying part name of IC in QFN16 packadge under SSD, near audio jack and 1206 capacitors (marked on photo). Unfortunatelly there is no refdes of that part so that is only info I can provide. I took boardview here on forum for revosion 2.0, but it doesn`t have this part at all, not just moved. Maybe someone have relevant schematic or BV.
            Notebook was poured with coffee and someone already tried to fix it but as usual made jusy worse. I`ve restored all mobo defects and now it powers up, starts OS booting but hangs on OS logo. I believe missing part may...
            10-04-2023, 04:26 AM
          • DynaxSC
            GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
            by DynaxSC
            I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
            General test conditions:
            - Tested with Core i5 6500 and Core I7 6700K - no difference
            - Default BIOS settings, but tried also altering several memory setting - does not change anything
            What is wrong:
            With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
            When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
            03-21-2025, 06:23 PM
            Thermal pad thickness for various laptop GPU / Graphics Cards
            ASUS Dual RTX 2070 OC 8GB
            ASUS ROG STRIX RTX 3080 OC
            ASUS ROG STRIX RTX 3090
            ASUS TUF Gaming RTX 3080 OC Edition
            ASUS TUF GTX 1660 S-O6G GAMING
            EVGA RTX 3060 Ti XC GAMING 8GB
            EVGA RTX 3060 XC GAMING 12GB GDDR6
            EVGA RTX 3080 FTW3 ULTRA GAMING
            EVGA RTX 3080 TI FTW3 ULTRA GAMING
            EVGA RTX 3090 XC3 ULTRA GAMING 24GB
            Gainward RTX 2080 Phoenix GS Specs
            Gainward RTX 3070 Phoenix 8GB
            Gainward RTX 3080 Ti Phoenix
            GIGABYTE AORUS RTX 3080 MASTER 10G
            02-09-2024, 08:08 AM
            A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
            by momaka
            More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
            And a shot of the label:...
            01-26-2022, 03:26 AM
          • nikovmiroslav
            Gigabyte A5 X1 Need Bios
            by nikovmiroslav
            Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
            Gigabyte A5 X1
            From motherboard:
            S/N: 1TNH55ER1350895
            P/N: 6-77-NH55ERQY-D02-2CGB
            On sticker from the back of the laptop:
            S/N: SN21351J000657...
            08-24-2025, 09:15 AM
