Blinking green light on motherboard - what does it mean?
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    I'm wondering what it means if, after turning off a computer and turning off the power strip to which the PSU cord is connected, that the green light on the motherboard (that indicates 5VSB power is being supplied) flashes a few times after the light itself shuts off? I would think this insinuates a short of some sort, which worries me...
    The system I speak of is the one I referenced in the first thread I created here. The motherboard is a D845PEBT2 and the power supply is an Hipro P3527F3. As stated before, the CMOS battery is dead. Does that have anything to do with it? ^^; This issue didn't arise until I installed this power supply, though (after the former Huntkey died, and after the FSP before it started having cold boot issues). Or rather, if it was there before, it certainly didn't come to my notice. Note that the computer in question is definitely in fine and working condition, I'm just wondering if the 'blinking green light' on the motherboard (after complete power off) could forebode danger somewhere down the road. Does this also have anything to do with cutting AC power?
    Thanks in advance for any answers.
  • ThePCDoctor
    Retired Tech.
    • Sep 2011
    • 59
    Re: Blinking green light on motherboard - what does it mean?
    EVEN after you kill the input line power to the PC, there's still a huge amount of energy stored inside all the PSU and motherboard caps.
    The flashes from the green LED just tell you that the stored power level is going down. To do a truly COLD boot, that green light should be OFF completely. Only then, can you be assured of a truly COLD boot.
    It's all normal!
    Enjoy!
    The Doctor
    Experience is truly the best teacher.
    Backup! Backup! Backup! Ghost Rocks!
    • dmill89
      • Dec 2011
      • 2531
      I'll second that
      Chances are the Hipro has much larger primary caps than either of those did and thus supplies power on the 5VSB longer when AC is cut. Hipro tends to use 680uf caps in their 300w PSUs while Huntkey and FSP generally use 470uf or 560uf caps in 300w units. Most Hipro's I've seen are very overbuilt (especially old ones) and are excellent PSUs, although they don't always use the best caps on the secondary (Teapo, SuScon, OST, etc.).
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        Thanks again for the responses. That's reprieving to know.
        I didn't open up the referenced Hipro (HP-P3527F3) power supply but I did stick a flashlight on one of the side vents and I noticed one large (680uf, as said before me) Teapo capacitor on one of the primaries, rated at 85C. I also might have spotted another Teapo in one of the secondaries. I guess Teapo on the primaries is better than Capxcon, though? (that's what the other Huntkey had, which was closer to being a 350W PSU, I think - it was of the Huntkey V Power 450 series, or a LW-6450HG, maybe, though it was rebranded by BFG as a BFG450GS and had thick heatsinks). Then again, I've read what's on the primary matters less than secondary capacitors in PSUs. But I did open up the older FSP (a FSP300-60BTV), which I think had Teapo (a LXK) on the primaries as well (might have even been 680uf), but one of the Fuhjyyus on the secondaries was bulged and leaking slightly... Not that it was a bad power supply. Save by its capacitors it had great heatsinks, a Pyrotechnic ball bearing fan, and seemed well designed.
        Not to be off-topic, though. Glad to know that a motherboard whose light is flashing after total power off isn't necessarily bad.
        • dmill89
          • Dec 2011
          • 2531
          Yah, What is on the primary doesn't matter much in non-APFC PSUs. Capacitance is important but brand means little so long as the brand accurately marks their caps, some no-name brands (Canicon,YC,Anodia,etc.) mark a much higher capacitance on the sleeve than the actual capacitance. Some really bad brands i.e. Fuhjyyu are known to have primaries fail but still at a much lower rate than caps on the secondary.
          Teapo is far from the worst brands, and they usually do ok in PSUs. They just aren't one of the best either, they're just mediocre. So far the only failed Teapo's I've seen in PSUs were in hot areas (usually next to/touching coils or resistors) high hours units (most had probably far exceeded their rated lifespan anyway).
          • Wester547
            • Nov 2011
            • 1268
            • USA.
            I've also read that Teapo and G-Luxon (sometime in the early 2000s, but I see dates from 2002-2005) merged. Does that mean that some Teapo capacitors may be closer to being G-Luxon capacitors (I guess it's drudging to tell, but to my knowledge, G-Luxon are not at all well reputed)? I don't doubt that Teapo do okay in PSUs, though the G-Luxon merger might explain why I've seen a number of posts complaining of bulged Teapos after a few year's of use (or give or take a couple), even in PSUs. But I could be wrong, of course.
            I've also read that Teapo do alright so long as they're not stressed.
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              Not to bump old threads, but I think I know why the motherboard's green light blinks for a few seconds after I disconnect AC power. It must be because there's 3 amps on the 5vsb rail according to the Hipro label, which I think is hefty for 5vsb, since most other supplies I see only have 2-2.5 amps on it and rather older supplies only had 1-1.2 amps. I don't know how "overbuilt" this PSU is, though, since it's a 300W but only has two 470uF capacitors on the primaries (it can still do 300W, but I'm guessing it will shut down at 350W) and its heatsinks are not particularly thick. However, it does look like it's full of components, so it doesn't look gutless either. I would also think that there's an overspec'd capacitor on the 5vsb rail.
              Sort of off-topic, but if there are faulty capacitors on the 5vsb rail, are they more likely to fail high or low (assuming they don't have the plague that the Bestec 1E series did, along with select Antecs), or is that too general a question? Failing high is of course worse and the end of the motherboard...
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                The reason for the flashing is due to the caps charging up after they have been discharged (ac power disconnected)
                once the voltage meets the start up threshold of the 5v standby it starts discharging the primary caps again this process repeats in-till the start up voltage can no longer be reached.
                All capacitors do this the higher the voltage and capacity the more it occurs.
                capacitors that are used in high voltage do it as well and is why after discharging the need to be shorted/low Resistance load across them to prevent recharging and causing injury.
                My pc
                CPU : AMD PHENOM II x4 @ 3.5Ghz
                MB : ASUS M4A89TD PRO USB3
                RAM : Kingston ValueRAM 16gb DDR3
                PSU : Cooler Master 850W Silent Pro
                GPU : ATI Radeon HD 6850
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  That's interesting. I've never seen it happen in any other system, though it could be because the capacitors on the 5vsb rail were probably of lower voltage and capacitance (as you said) so it might have reached occurrence less often (or I might have disconnected AC power less often if at all).
                  • jxrepman
                    Asus X453MA won't turn on and green led light blinking
                    by jxrepman
                    Hi there,
                    I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                    I have checked the charger and it is giving 19+ V
                    I have disconnected the battery and pressed power button for 30 seconds.
                    I tried another RAM stick.
                    Tried disconnecting the keyboard and touchpad.
                    Tried disconnecting the HDD and the wifi adapter.
                    The problem persists.
                    Hope you could help me out on this one. Thank you.
                    12-14-2024, 06:40 AM
                  • MOSSEP
                    Monitor Audio RSW12 - Green light, but no sound
                    by MOSSEP
                    Hi
                    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                    I have already tried replacing all of the...
                    01-26-2025, 08:33 AM
                  • MOSSEP
                    Monitor Audio RSW12 - Green light but no audio
                    by MOSSEP
                    Hi
                    01-26-2025, 08:18 AM
                  • naddaw000
                    Toshiba 55U7863DG - green light blinking (17MB130S)
                    by naddaw000
                    Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                    I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                    12-02-2023, 01:35 PM
                  • ItepK
                    Panasonic TX-P42G30E green light blinking, no video, no audio
                    by ItepK
                    Hey everyone!
                    I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                    This post describes my entire troubleshooting process of this TV.
                    When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                    I've taken the unit apart, and I've started to check some voltages:
                    • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                    12-22-2023, 05:06 AM
