My Latest 8-core Project
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    I have a source that contacts me usually once or twice a year and trades me a goodie box of various computer boards and hardware for some caps....well he calls and says there's a box headed my way. I asked what was in it, and he emailed me the list... Mostly a bunch of Dell GX745SFF boards in need of recap....but in every bunch from these guys, theres always a gem, and here it is:
    http://www.supermicro.com/products/m...00/X7DWA-N.cfm
    Its brand new, sealed in the retail package.....they couldn't test it as they don't have any processors for it...so they didn't even open it. AWW YEAHS!!! Looks like the Frankenserver's innards will be retired soon.
    I got the goodie box including this board for about $50.00 worth of caps!!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • c_hegge
    • Sep 2009
    • 5219
    Re: My Latest 8-core Project
    WOW. I wish I got scores like that more often.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5046
      • US
      right now the xeon 5150 771 seems to have dropped a few hundred bucks
      http://www.amazon.com/Intel-1333MHz-.../dp/B000I1OFK2
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Nice... its a supermicro too...
        I have a suggestion for the old innards of the frankenserver: put them in that massive server case you recently cleared out (where my X5DAL came from) and make another system...
        sigpic
        (Insert witty quote here)
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          I actually thought about that. I'm not sure if that case can take an eATX board though...I'd have to see. The problem after that, I'd have no real use for it after that...
          These are the CPU's I was looking at, seems like the best bang for the buck.
          http://www.ebay.com/itm/320842242142
          $42 bucks a pop with a 12mb cache....cant beat that with a stick!! I still have to hunt some DDR2 ECC. I have like 4gb worth of it to test with, but I'd probably run it with 32gb....the board maxes at 64gb, but good God in heaven, what would I need 64gb of RAM for (or even 32 for that matter)...
          Team : 49813
          Join in!!
          Team Stats
          • gg1978
            • Dec 2004
            • 431
            Nice board. Don't forget ya need FB-DIMM's for it though, i had to order some for the Dell Server at work once.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              True EATX cases are hard to find for cheap...
              if you find an old roomy case with a non-centered floppy /hdd or an old white gateway case you can dremel it into a hacked EATX case... I'me doing that to my modded gateway so I have a proper home for my massive EATX dual PIII board. To do this I will have to trim more off the HDD cage (it will only hold 2 HDDs instead of 3).
              The board's old case was a poorly modded old ATX case with the lower 3 cdrom bays cut out... there may be pics of it around here from a few years back.
              sigpic
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                Scored a pair of these for it today.... $140 shipped for a pair....couldn't even find them that cheap on fleabay!
                http://www.cpu-world.com/sspec/SL/SLANR.html
                I'm a big fan of the "E" series (low power consumption) Xeons....good overclockers, run cooler, less stressful on the motherboard and PSU....just a little pricier...
                Team : 49813
                Join in!!
                Team Stats
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  That's gonna be super fast!!
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    Seems I've hit my first obstacle. Yes, this board does require fully buffered memory....I knew that already....but with the CPU's @ 1600MHz FSB, to run the memory full speed, I need FB/ECC PC6400 (800MHz) DDR2....good luck finding that!! It seems to be nearly non-existent...and when I do find it, bend over!! I can get DDR2 FB/ECC PC5300 (667MHz) for next to nothing (like 16gb of it for $100 bucks).... The CPU's will of course run at full speed...but the RAM won't unless I force it (BIOS actually has an option for that)....so this should be interesting.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • mariushm
                      • May 2011
                      • 3799
                      http://cpubenchmark.net/cpu_list.php
                      140$ [Dual CPU] Intel Xeon E5472 @ 3.00GHz 9561 Passmark points
                      250$ AMD FX-8150 Eight-Core 8243 Passmark points
                      320$ Intel Core i7-2600K @ 3.40GHz 9092 Passmark points
                      Hmmm... even with the free motherboard, is it really worth anymore?
                      The 2 cpus and the fbdimm memory will eat loads of power - won't you get charged extra by the datacenter for it?
                      Something like a FX8150 + $60-80 mb + cheapo ddr3 seems more reasonable, and you'd get almost the same performance.
                      Well now since you already bought the cpus you're already committed i guess...
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16959
                        Ohh absolutely. I already have the case and all the extras. At the end of teh day, I'll have less in it this entire system core (CPU's, motherboard, RAM) the price of the I7 CPU alone @ $320 in your above statement....and this thing outscores it according to your info source....That's a pretty nice deal to me.... By the time I bought a good motherboard and all the supporting hardware for the I7, I'll be out a hell of a lot more than $320! These are E series....they consume about the same as the I7....of course that's x2, since there's a pair, so combined, its 160W at full load.... I can't believe you even asked this... Supermicro (bulletproof motherboard) compared to some 80-dollar cheapo? Come on now!! In 5 years, this thing will still be cranking along and not quitting anytime soon! A cheapo board in 5yrs will probably be dead and gone....or in need of a recap...heh...I wonder if I know anyone who could do that!
                        If I were worried about paying my electric bill, I wouldn't be buying/building this kind of stuff...
                        Team : 49813
                        Join in!!
                        Team Stats
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5046
                          • US
                          yeah and completely different uses. server vs gaming desktop
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16959
                            Indeed. I dont game. I build high end workstations and servers.....I dont build gaming rigs.
                            FWIW, my main rig was built Feb 2009. To build the exact same rig today would cost me 500 bucks more than it cost me back then. The processors went up in price (e5520 nehalems), the HDD's went up, and the barebones went up... the only piece that dropped was the memory, and it wasn't by much.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5046
                              • US
                              Even ECC RAM is not that special, as some AMD chipsets support it on regular motherboards.
                              its the am2/3 processors themselfs that support ECC, but only asus boards have the option to enable it
                              One of the main things that server boards i've seen that gives advantages over regular boards is the onboard management software. Turn one off/on flash bios and some will let you even kvm it remotely.
                              aside from that, I put the hardware quality up there for some of them with gigabyte, some, like supermicro are even better
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16959
                                woohoo....processors should be here tomorrow!
                                Team : 49813
                                Join in!!
                                Team Stats
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16959
                                  Just a few teasers while I wait for the RAM to get here....
                                  yea, thats a big board!!
                                  The money shot!!
                                  Other crap...
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    What about the coolers?
                                    didn't you have a bunch of gx280 coolers that you could zip tie fans to? or are those screwy?
                                    sigpic
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16959
                                      I have a couple of choices for permanent ones...but for testing purposes, I just use the bench coolers.
                                      New thing I learned, FB DDR2 is keyed different than ECC DDR2.... I have some ECC DDR2 667MHz that I figured would be ok to test the board...nope. Won't even fit the slot. Fully buffered DDR2 uses a slot of its own apparently.....I never knew that. I did fire it with no RAM in it...and it beeped memory codes at me.....obviously...but it is a good sign. That tells me the board is alive...
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Let me guess, the RAM you need is pricey?
                                        sigpic
