My Latest 8-core Project
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
Re: My Latest 8-core Project
Well, it happened this morning....one of my 27" monitors shit the bed.... The panel went bad (common for the Dell 2709W), so no fix....it's been deteriorating for some time now. I saw this coming, and had a backup plan.....
Say hello to 3x Dell u3011's, 2560x1600 16:10 monitors. I bargain hunted for a long time....I've got less than $400 in all these, screens are flawless. I was worried these would be too overwhelming for the desk....but after setting them up & tweaking, I should have done this long ago!
Attached Filesif you find these attachements useful please consider making a small donation to the site
Team : 49813
Join in!!
Team StatsComment
Be careful - you might get some serious computer tan now!
The monitor on the left looks barely on the edge of the desk, though.
Next up: bigger desk upgrade?
BTW, often there are quite a few really nice solid wood "executive office" desks for dirt cheap (sometimes even free) on my local CL, as there are a lot of gvmnt/admin offices in the area. If only you were closer.Last edited by momaka; 03-25-2019, 09:19 PM.Comment
So they're cheap like those Sharp 70-inch'ers! You said "common", so I think it's safe to say bad like Sharp, not too long before Hisense bought their TV division, IIRC.
It makes me sick to get word about that happening with a Dell computer monitor! I'm used to getting word at badcaps.net, about failures with TVs, OTOH. (the ones with a tuner) Or Core 2-era LCD monitors with bad caps.
Except for bad CCFLs or the like, of course, for earlier LCDs.Last edited by RJARRRPCGP; 03-26-2019, 05:19 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
I got to my office this morning, fired this system up as usual....POST roll halted @ SAS init, saying a drive was missing from the 600gb RAID10 (4x 300gb Cheetah 15k RPM SAS).....sure enough, one had died. It boots just fine on the degraded array, I didn't have another HDD on hand to swap it out....so I'm runnin' on 3 at the moment....got another on the way....but redundancy saves the day!!<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Curious to read more about the dead 300 GB Cheetah HDD. Is it clicking? Or just not recognized? I wonder if the Seagate server HDDs have the same problem with their head amp contacts oxidizing like the desktop lines do, and if there is a slim chance that might restore yours. I just cleaned and tinned the boards on 4 different Seagate models, ranging as old as the 7200.10 era and as new as the SV35 series. Unfortunately, that doesn't seem to have helped any of them, though. Half of those have bad sectors and click very unpleasantly once in a while, while the other two appear and read/write OK, but can't pass a thorough surface test. All high-hour count HDDs with low power cycle count. In my experience, Seagate HDDs like it the other way around: high power cycle count and low hours - at least the desktop models anyways. Seems after 20-40k POH, they start to act up.Comment
It's a 15k.5. It was making some weird whining noises, like it was only partially spun up to speed (maybe a bearing failed). It was not clicking. Controller showed it, but as 'failed'. I didn't even bother looking at the SMART data.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Speaking about HDDs, on Western Digital HDDs, I'm noticing what looks like a lot of corrosion!
Looks like corrosion, even on Blacks, too!ASRock B550 PG Velocita
Arc A770 16 GB
Low quality contact pads..... Remove the interface boards from the drives and take an eraser to the contact pads if they're corroding. Your HDD will thank you for it. WD is bad about this.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
How the feck can I stop that corrosion? I saw that the corrosion is particularly bad, at least on Western Digital HDDs since circa-2010!
Then I looked at one of my Seagate Barracuda HDDs from roughly the same time and it looks like they hardly corrode, if at all!ASRock B550 PG Velocita
Arc A770 16 GB
I typically put a dab of non-conductive dielectric grease on them, it stops the corrosion dead. Do this for the motor & head interface on the underside of the PCB (it has to be removed from the drive).<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Yup, anything made after the RoHS era is like that.
Seagate is not any better either, though.
+1 for the pencil eraser trick. I do that to clean the contacts first.
Either what TC suggested with the contact grease.
-OR-
If you are a solder monkey
- coat the pads with leaded (Pb) solder. That's what I do all the time now. Just don't apply too much solder. It only needs a thin coating on there. Afterwards, clean with IPA to get rid of solder flux, as that can make the contacts non-conductive - obviously not what you'd want to happen.
IIRC some of the 7200.11 Seagates can be brought back from the dead with a USB serial adapter. I myself have made one from a Nokia USB cable (DKU-5) and have saved several Seagates.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
This happened again this morning, another Cheetah HDD checked out, that's the second of the original 4. The first one I replaced with a used one (the one that failed this time was not the same one)...but I didn't have another to replace it, and you can't find these new anymore anyway..... I did have 4x 300GB 15k 128mb cache 2.5" SAS new-in-baggie (hitachi IIRC). Mounted on WD icetrays, they slip right into the SM 3.5" caddies, and away I go. Used clonezilla (saw the RAID arrays)...cloned, and done. The old clumsy 8yr old drives are phased out. the 2.5" are also faster and silent. Win! Anything to keep this system limping along a little longer....since I'm still getting Win7 updates for another year. I actually have a replacement for this system simmering on the back burner.....if anyone remembers that M6000 incident....I got to my office this morning, fired this system up as usual....POST roll halted @ SAS init, saying a drive was missing from the 600gb RAID10 (4x 300gb Cheetah 15k RPM SAS).....sure enough, one had died. It boots just fine on the degraded array, I didn't have another HDD on hand to swap it out....so I'm runnin' on 3 at the moment....got another on the way....but redundancy saves the day!!
Team : 49813
Join in!!
Team StatsComment
Same type of failure on the HDD?? (bad bearing and HDD making excessive bearing noise??)
Curious what fails on these server-grade HDDs.
With the desktop models... particularly 7200.10, 11, 12, and anything onwards, it seems to be a combination of bad surface, head wear, and bearing wear. As stated previously, seems that desktop Seagate HDDs don't like high power-on hours. Power-cycle them daily when PC is not in use, and they tend to last a lot longer in terms of years (but not POH.)
Nice!I did have 4x 300GB 15k 128mb cache 2.5" SAS new-in-baggie (hitachi IIRC). Mounted on WD icetrays, they slip right into the SM 3.5" caddies, and away I go. Used clonezilla (saw the RAID arrays)...cloned, and done. The old clumsy 8yr old drives are phased out. the 2.5" are also faster and silent. Win! Anything to keep this system limping along a little longer....since I'm still getting Win7 updates for another year.
I like Hitachi HDDs. They seem to be pretty reliable for the most part. Only the older 500G 2.5" laptop models weren't so great. But apart from those, I have seen many Hitachi with 100k POH.
This one just went dead. No spin-up, no communication with the interface (can't even read SMART data). At first, I thought the SAS port went until I tried the drive on a different port with the same result.
I didn't check their POH hours when pulling them....but it's been 8yrs running 24/7/365 the first 6 years. About 2yrs ago I started shutting it off at night, so it runs ~10hrs/day now.With the desktop models... particularly 7200.10, 11, 12, and anything onwards, it seems to be a combination of bad surface, head wear, and bearing wear. As stated previously, seems that desktop Seagate HDDs don't like high power-on hours. Power-cycle them daily when PC is not in use, and they tend to last a lot longer in terms of years (but not POH.)
I'm happy with them so far. I got them for $11.00/drive, that's one nice thing about SAS...not many things support them....not a lot of demand. I run them in a RAID10, that's 600gb. Plenty of storage. I keep large storage on the NAS, so massive storage isn't needed on workstations.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
This one is still going. It's the only Windows 7 system remaining in my fleet. It has a lot of legacy utilities on it that I still use....and legacy hardware support (floppy). Browser support is dried up and win7 is otherwise pretty useless....and to add more insult to injury this system has mechanical HDD's in it; granted they're 15K RPM in a raid10... The problem, I needed a system at the bench with modern browsing capabilities...but don't want to waste bench space with another PC. The solution was simple, shrank the 600GB partition by half and dual booted it with MInt 22. Problem solved and this one lives on!
Mint 22 performs very nice on this antique even with the spinning HDD's. Best of all worlds until this thing dies.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by Artem2009-16Hello everyone,
I’m currently working with an Intel DQ965GF motherboard and would like to upgrade the CPU.
However, I can’t find the latest BIOS version or a working download link for it — the official Intel website no longer provides this file.
Could someone please share a copy of the latest BIOS update (preferably the final release version)?
My goal is to upgrade the processor from a Core 2 Duo E6700 to a Core 2 Quad Q6700, so I’d like to make sure the BIOS fully supports... -
by Smartec82Hello,
Does anyone know the Project ID of the Thomson 55UC6406 , panel: LSC550FN11-906? The picture appears duplicated and I can't change it in the service menu. I can only change the Project ID by pressing 062598, pressing 3 dashes, ID.10-03-2025, 11:30 AM -
by sam_sam_samRight now Battery Hookup has these e-bike battery packs that are used but I am going to remove them and test them and see how good they are and maybe resell or reused them for another project this is for another day
When I get the rack mounted enclosure that I mentioned in another post I will see how well they fit in the enclosure and how much room I will have left
https://batteryhookup.com/products/3...ttery-with-bms
These battery packs are a little bit hard to get out of the enclosure because they were a little bit glue... -
by BladibladI have an interesting project here. I have a HP RTX 3060 12GB VRAM GPU with a shortcircuit between a (what I believe is) a coil and a cap. The short circuit is so bad that it will trigger a failsafe on the PSU.
I'm a beginner in this field and have managed to do only very simple board repairs so far. I have basic understanding of the components (mosfets, caps, nand chips) but completely diagnosing a board with schematics would be challenging. In this case though, I'm going to hope that replacing only the two shorted components will bring the card back to life (if none of the IC's... - Loading...
