Hitachi GST unveils perpendicular HDDs
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Yoshiko Hara
    EE Times
    (05/17/2006 11:25 AM EDT)
    TOKYO - Hitachi Global Storage Technologies has started shipping
    perpendicular 2.5-inch hard disk drives, seeking to break through the
    capacity ceiling of longitudinal drives.
    Its first 2.5-inch product family, dubbed as Travelstar 5K160, has a single
    platter with 80 Gbytes of capacity, or two platters each with 40 Gbytes of
    capacity. The platter's areal density is 131.5 Gbits per square
    inch.
    PeteS in CA
  • arneson
    • Sep 2005
    • 1267
    Re: Hitachi GST unveils perpendicular HDDs
    That really amazes me.
    What's next? A small glob of bio matter shaped like a brain lobe?
    I've been into the little drives and can occasionally free up a sticky head or disk
    and was aware of the half size 2.5 but it is amazing technology.
    Jim
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
    • wolf1976
      hitachi 50hk5600 problem with display
      by wolf1976
      hi
      i have the above tv and the display starts distorts the display at only in applications like you tube
      after and on the didital channels
      now without connect the antenna only the image of itsselfs tv i have the image i have in attach
      i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
      can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
      09-13-2025, 02:26 PM
    • massimomax
      Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
      by massimomax
      Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
      spero che qualcuno può averlo per riprogrammare eprom. grazie
      Post in English !!!
      I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
      02-28-2025, 07:27 AM
    • dragometin
      Hitachi 40HYC42
      by dragometin
      TV Model: Hitachi 40HYC42
      Power Supply: 17IPS71
      MainBoard: 17MB95M
      Panel: VES400UNDS-2D-NO3
      When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
      I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
      Is there any variants on 17IPS71 power supply's?
      UART output pins 10 and 12 on scart connector:
      Code:
      12:24:04.595
      08-08-2024, 05:53 AM
    • sotodefonk
      Help finding the correct model of a T-Con board on my Hitachi TV
      by sotodefonk
      Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
      I opened the tv to access the board and took the shared pictures of the T-Con board.
      I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
      I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
      Inspecting...
      06-28-2024, 04:39 PM
