Old AMD CPU naming system
  • ncovert
    • Feb 2011
    • 291
    Hi all, I was wondering why, on old AMD CPU's, that they name it like Athlon XP 2600+ when the clock is 2.133Ghz. Does anyone know why they did that?
  • shadow
    • Feb 2007
    • 732
    Re: Old AMD CPU naming system
    From the top of my head, an AMD Athlon XP 2600+ is clocked at 2.1333GHz, however it is equivalent to an Intel Pentium 4 2.6GHz (the Netburst based Pentiums).
    • 370forlife
      Large Marge
      • Aug 2008
      • 3113
      It was suppose to be their intel equivalent speed.
      • mariushm
        • May 2011
        • 3799
        There was a processor company Cyrix which made (Super) Socket 7 compatible processors that were about as fast as some Pentium processors at arithmetic operations yet they were running at lower frequency.
        For example they named their CPU P166+ while they internally ran at something like 120-133 Mhz,
        AMD later adopted this trick because they considered the Mhz was no longer good performance indicator, as the Netburst architecture of Intel was designed to scale very high with the Mhz but not deliver performance.
        So the 2600+ simply says the AMD processor would behave like a 2600 Mhz Pentium 4 in most normal tasks people use them for.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          Officially, AMD said the XP____+ rating would be the equivalent speed a Athlon Thunderbird (the original Athlons.. non-XP, ceramic package) would have to run at to perform about the same.
          In reality though, it was more like the Pentium 4 equivalent speed, i.e. Athlon XP2600+ (2.13GHz) performed about the same as a P4 2.6GHz.
          The Athlons were much more efficient ("do more work per MHz"), but that was bad from a marketing standpoint. John Doe who's out to buy a new computer would probably not believe a Athlon XP at 2.13GHz is faster or at least on the same performance level than a Pentium 4 2.6GHz.. ("higher number is better, right?")
          It was a combination of the CPUs (Athlon XP's) being more efficient per MHz and marketing.
          The Pentium 4 was designed from the ground up with high clockspeeds in mind, neglecting efficiency. And in the end, that's what killed them... nobody wanted a singlecore CPU using close to 100W of power (for example the Pentium 4 Prescott lineup) or a Dualcore cobbled together from two Pentium 4 CPUs using 130W or more (Pentium D 830) and putting most of that out as heat instead of computing power..
          Even intel realized that the Netburst architecture (which was the Pentium 4's / Pentium D's "base platform") was a dead end. They then took the very efficient Pentium M notebook CPU lineup (which were heavily modified Pentium 3) as a base, modified it even further and later came out with the Core Duo and Core 2 Duo.. and I probably don't need to tell you how successful they were..
          /historylesson
          • Newbie2
            • Sep 2005
            • 885
            I have to admit, in the past I fell for the high clock speed of the Pentium 4 versus the AMD processors, thinking it'd mean better performance.
            Back in '05 when I was a bit younger (didn't know as much as well) and wanted to build a PC, the two processors that I was looking at were the Athlon 64 3200+ 2.2GHz in Socket 754 and the Pentium 4 HT 3.2GHz Prescott in Socket 478.
            At the time I thought the Pentium 4 was the better buy and so I bought it, being 1GHz higher in clock speed than the Athlon 64 and having Hyper-Threading technology (which actually doesn't make much a difference). Looking back, I should've chosen the Athlon 64 because it was a 64-bit processor (vs. the 32-bit P4), had a much lower TDP (59W vs. the P4's 89-103W), and overall it had around the same performance as the Pentium 4 HT 3.2GHz in benchmarks and applications.
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
            • ncovert
              • Feb 2011
              • 291
              I did not know they made Socket 478 Prescott CPU's; or at least had never seen one.
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                They made some - http://en.wikipedia.org/wiki/List_of...icroprocessors
                But a majority of them were LGA775
                Ludicrous gibs!
                • Newbie2
                  • Sep 2005
                  • 885
                  My old Pentium 4 3.2E Prescott in Socket 478 has the S-Spec number of SL7PN. This is what it looks like:
                  I'm going to give it away in a rebuilt PC to one of my aunts soon, since she doesn't have her own computer yet.
                  My gaming PC:
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    full list of all prescott P4's
                    http://www.cpu-world.com/CPUs/Pentiu...0Prescott.html
                    ..and all P4's in general, regarless of socket and core
                    http://www.cpu-world.com/CPUs/Pentium_4/index.html
                    Personally, I've tried to go for the slightly older Northwood P4's on S478. They just ran much cooler and were available up to 3.4GHz (some with HT).
                    On LGA775, you're pretty much out of luck, as there's only Prescott and Cedar Mill.
                    Any LGA775 board that doesn't support Core 2 based CPUs yet is pretty much worthless IMO.
                    Some i945G's and most i965/i975 support Core 2 based CPUs, which includes Celeron S series (S 420 - S 450), Celeron Dualcore, Pentium Dualcores (not to be confused with Pentium D) and of course Core 2 Duos.
                    One easy way to tell Pentium Dualcores (core 2 based) from Pentium D's (Pentium 4 x2) is the model number.
                    - Pentium dualcore model numbers always start with an "E" and have a 4 digit model number (like E2180)
                    - Pentium D model numbers always start with a "D" and a 3 digit model number (like D820)
                    • ncovert
                      • Feb 2011
                      • 291
                      I actually have an Athlon XP 2600+ in an Asrock K7S41GX board. Its a decent overclocking board, that is, its easy to do.
                      • Lenny_Nero
                        • Mar 2010
                        • England
                        It was because the AMD chips could get more done each clock cycle than the then Pent IV, so the 2600+ did the same work as a 2.6 gHz p IV.
                        Something AMD have been really good at (working smart), Intel just put more on die cache needing 10's of millions of trannys to get a few 100's of MHz speed bump, where as the Tbreads (before and after) only needed a few 1000's of trannys to get the same MHz boost.
                        Until Intel RE'ed the Opteron and called it the i3/5/7 range that was there only way to gain real speed ...or so I was told.
                        I still use (everyday) a box I built around a 2600+ (I have a 2500+mobile to put in and play with when I can find the time) some 8~9 years back, can do everything any avg user would need today.
                        Its my local usenet/Pdf/doc server, and have stuff open in palemoon[Firefox] and sitting there for me to read and research.
                        Edit...Damn Jscript was off I could not see any replies, sorry
                        • severach
                          • Aug 2007
                          • 1055
                          Intel got it right with the Core 2 Duo.
                          Anandtech: Intel's Core 2 Extreme & Core 2 Duo: The Empire Strikes Back
                          But make no mistake, what you see before you is not the power hungry, poor performing, non-competitive garbage (sorry guys, it's the truth) that Intel has been shoving down our throats for the greater part of the past 5 years. No, you're instead looking at the most impressive piece of silicon the world has ever seen - and the fastest desktop processor we've ever tested. What you're looking at is Conroe and today is its birthday.
                          AMD was conservative with their plus ratings but unfortunately no single core at any speed can match the crispness from the lowest multiprocessor core: Pentium 4 2.4/800 HT.
                          sig files are for morons
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            I used a lot of those back in the day...
                            I skipped P4 in socket 775 completely and went to sockets 771(XeonC2) and 775(C2D).
                            Mann-Made Global Warming.
                            - Dr Seuss
                              ACER Predator 610-UR10P Predator G3 i7-2600 Specification for Upgrade or Repair
                              This specification for the ACER Predator 610-UR10P can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator 610-UR10P boardview and Predator 610-UR10P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-12-2024, 03:36 PM
                              LENOVO ThinkCentre M91p ThinkCentre M i7-2600 Specification for Upgrade or Repair
                              This specification for the LENOVO ThinkCentre M91p can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M91p boardview and ThinkCentre M91p schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              ACER Veriton 6610G Veriton M i7-2600 Specification for Upgrade or Repair
                              This specification for the ACER Veriton 6610G can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton 6610G boardview and Veriton 6610G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER...
