CD burning problem
  • Tom41
    • Oct 2005
    • 339
    • England
    Re: CD burning problem
    I've tried all that stuff, changing the IDE cable for a different one, swapping over the Master/Slave jumpers (so the drives are effectively reversed), and it didn't help. Anyway, took it back to the store, they gave me a replacement straight away. All I needed to say was that it wasn't reading or writing (not working as advertised ).
    I've now got the exact same make and model, but a brand new drive. So far, it's doing pretty well. I've been doing some tests on it the past couple of days:
    Passed - Reading store-bought CD-ROMs
    Passed - Reading DVD+RW burnt on another machine
    Passed - Burning brand new DVD+RW (read test ok)
    Passed - Erasing DVD+RW
    Passed - Burning new DVD-R
    Passed - Burning new CD-R
    Intermittent - Burning on previously used (and erased) DVD+RW
    Failed - Playing movie DVDs
    The first time I burnt onto that previously used +RW, it burned, said OK but other drives said the disc was an unrecognized format. The second time, it burned to completion, ejected the disc then immediately closed the tray and started formatting it again! O.o
    The third burn was successful; all files read on the other PC and they were valid files - not just blank ones.
    Basically, I'll keep on doing test burns (when I can get on the computer), and see what happens. If the drive dies within a week, it's back to the store again - this time for a different brand
    You know there's something wrong when you open your PC and it has vented Rubycons...
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
    • Gibon378
      Problem with stopping audio and video for no reason
      by Gibon378
      PC Specs:
      • CPU: Ryzen 5 1600
      • GPU: GTX 1080 Palit JetStream
      • MOBO: ASRock ab350 PRO4
      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
      • PSU: XFX 650W (don't remember what model)
      • OS SSD: ADATA SP920
      • OS: Windows 10 21H2
      Problem description:
      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
      11-19-2022, 09:41 AM
    • perzyk23
      Lenovo T580 - LCD Panel problem - error 0288
      by perzyk23
      Good morning,
      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
      10-25-2024, 12:42 AM
    • lazaro.089
      Asus Zephyrus M16 / GU603ZW problem
      by lazaro.089
      Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
      CPU: Core i9-12900H
      Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
      Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
      The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
      08-26-2025, 06:33 PM
