PCMCIA slot fillers
  • stevo1210
    • Oct 2006
    • 4156
    PCMCIA slot fillers
    The slot filler for the PCMCIA slot on my Toshiba Portege R200 is missing, so I have this gaping hole on that side of the laptop. What should I fill the hole with?
    I was looking for blanking pieces but they don't exist on ebay. so i was thinking... a cheap SD card reader or the like should do the trick right?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: PCMCIA slot fillers
    I can send you one? Would a dell one work?
    Edit: crap, you live in Australia.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      ebay it. uber cheap, since nobody really cares about them.
      sigpic
      (Insert witty quote here)
      • mariushm
        • May 2011
        • 3799
        Fill it up with something like this:
        http://www.dealextreme.com/p/2-port-...-laptops-24875
        http://www.dealextreme.com/p/pcmcia-...-laptops-13731
        http://www.dealextreme.com/p/laptop-...-adapter-23791
        http://www.dealextreme.com/p/4-ports...notebook-52835
        Free shipping, from Hong Kong, so it should get to you fast. And it's useful.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Originally posted by mariushm
          useful, till it burns out. those things suck. i would't use them in a laptop i cared about.
          plus, DX knowingly sells counterfeit caps, so I personally boycott them.
          sigpic
          • mariushm
            • May 2011
            • 3799
            The 5$ compact flash to pcmcia is a passive device, nothing burnable inside - so if you don't use it, it's just like a basic plastic cover.
            I can understand the boycott but take the items above as suggestions and hit the ebay.
            • stevo1210
              • Oct 2006
              • 4156
              What's a passive device? :S
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                that means a port-to port adapter, with no circuitry other than wires and 2 ports. CF and pcmcia use the same signaling.
                sigpic
                • stevo1210
                  • Oct 2006
                  • 4156
                  Well I managed to find Toshiba R100 slot fillers. I have an R200 though. But looking at the images, they are exactly the same in size and shape... only difference is that one is black (R100) and the other is grey (R200). $18 will have to cut it. :S
                  • b700029
                    Banned
                    • Sep 2010
                    • 640
                    $18 for a piece of plastic?
                    See above, you can add two USB ports or a CF slot for less than half the price.
                    • totoagung2
                      by totoagung2
                      Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
                      Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
                      01-01-2024, 02:43 PM
                    • silberdrache
                      Burnt Hole under IC on MacBook Pro M1 Pro 14"
                      by silberdrache
                      I'm new to this Forum, so I hope it's the right place for this topic.
                      Im a student from germany, and as a hobby I repair electronics. I started microsoldering maybe 1-2 years ago.
                      I have a MacBook Pro 14" m1 Pro with 10 Cores and 16/1tb storage. The board Number is 820-02098-A.
                      The MacBook has a light water damage. Coffee got spilled over it, but the Mac continued working only the battery didn't charge anymore and when the battery was empty the Mac turned off and doesn't show any sign of life now.
                      I opened it up and there were only three drops of coffee...
                      11-10-2025, 11:19 AM
                    • Lifeisfun
                      Trying to troubleshoot DDR4 SODIMM slot with slot tester
                      by Lifeisfun
                      Hi folks!
                      I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                      Eventually I discovered that it was related to moving the laptop.
                      Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                      If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                      I removed the board got one of those memory slot testers...
                      06-04-2025, 02:26 PM
                    • szepesif
                      Lenovo Ideapad 3 15IIL05 working perfectly with onboard RAM but it doesn't start when I add a memory into the RAM slot
                      by szepesif
                      Hey guys!
                      I don't know the solution to this problem, but this is definitely not unique and I would like to figure out the solution to fix these in the future.
                      I have two identical Lenovo Ideapad 3 15IIL05 laptops with integrated 4GB DDR4 memory. Both work perfectly with that. BUT... if I add any extra memory to the single RAM slot, it never gives a picture. I thought the RAM slot pins would be the problem but no, all pins are solid (I checked them under the microscope). The RAM in the slot has 1.2V, so the voltage is present on the module. I flashed the latest BIOS, so
                      04-19-2025, 10:18 PM
                    • Byte_76
                      Faulty memory slot on Tekram Slot 1 motherboard
                      by Byte_76
                      I have a Tekram P6PRO-A5 Rev. 1.01 which has an issue with one of the memory slots and with the floppy port.
                      When a memory module is installed into the slot which is closest to the north bridge, the board will beep and won't post. The same memory module works in the two remaining slots.
                      Also, the floppy drive does not work regardless of bios settings.
                      Please help me to identify the possible cause of the faulty memory slot and the floppy drive port as well.
                      I have examined the board under my digital microscope and did not find any broken traces....
                      04-12-2025, 06:58 AM
