linux nvidia drivers
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Hello everyone!
    So, i installed linux mint 11 on two PCs...both with nVidia. (One integrated and one has PCI-Express)...
    Withthe stock drivers, the display resolution (1024x768 in this case) is fine.
    But then it says there are better nVidia 3D drivers available. They installed fine, but then after reboot my screen is stuck in 640x480!!!
    Is that because i need drivers for my monitor? Or what?
    Both computers had this problem...
    Thanks.
    Also, a recommendation on media center would be good
    Ps: uninstalling the driver fixes the issue...but i want to use the driver!
    Linux commands: i am good at it!
    Installing drivers: fail!
  • mockingbird
    • Dec 2008
    • 5484
    Re: linux nvidia drivers
    I would uninstall the package with apt-get and then download the binary installer straight from nVidia's site.
    I think the way to install them is to switch to a non GUI shell (CTRL-ALT-Fx - Any of the F keys), issue the command /etc/init.d gdm stop (I think there's a newer command they use now), and run the binary installer (sudo ../nvidia-driver-file).
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      I'll try that. I actually can't use either of the computers right now, (most of my stuff is in moving boxes, and my garage workbench is piled with crap), but I'll give that a shot. Thanks!
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        WAIT- I've seen this before. Easy fix.
        go to a terminal and type "sudo nvidia-xconfig"
        when that is done, then run "sudo nvidia-settings"
        go to the 2nd tab, xserver display configuration, and change the resolution to what you want. then click "apply", and see if you like it. if not, change it again and hit "apply". Once you are done, click "save to X configuration file" and follow though the dialog boxes, selecting the default options.
        that should fix it...
        sigpic
        (Insert witty quote here)
        • mockingbird
          • Dec 2008
          • 5484
          Also, run lsmod and see if a module called "nouveau" is running. That's the open-source nVidia driver. You have to blacklist it.
          Unfortunately driconfig didn't work with nVidia drivers the last time I checked. They said they were working on it, but who knows.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Nouveau is automatically disabled when one installs the prop. driver... It is under fedora and I am pretty sure Ubuntu and mint are the same way.
            Even in a failed install... I tried to make a fx5200 fly but even the 173 driver failed and sent me to vesa, not nouveau (lsmod confirmed). I went back to nouveau since for what I wanted it worked better (nouveay has 3d support and is gnome-shell compatible)
            sigpic
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Yeah but I thought the stock driver has no 3D/or 2D acceleration support either!!! That's why I updgraded to the real nVidia driver
              • mockingbird
                • Dec 2008
                • 5484
                Not that I remember.... At least this was around have a year ago with the 260 drivers. The driver even warns you that you have to do this yourself...
                Maybe the newer ones do it automatically. Keep in mind, I wasn't refering to the Aptitude package, I was refering to the binary... If you're going to do it through aptitude, you may as well use a backport. Ubuntu repos usually have older versions.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Well, I'll check out the PC in 5 minutes or so (I dug out a monitor and keyboard and mouse) and see what I can do!
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    it has support but it isn't as good... games that are 50fps under the prop. driver are choppy under nouveau... it is getting there but they haven't fully reverse engineered it yet.
                    sigpic
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Let me explain the situation:
                      PC #1: HP with nVidia integrated into the motherboard. I want this one to work well and reliably, I don't care about performance all that much, since I'm going to sell it at a garage sale, and you can't do games on Linux esp. on integrated graphics...
                      PC #2: It's going to be my media PC in the new house. It's a p4HT 3GHz (socket 775) in a funky sideways case with an antec fanless PSU I stuck in there and a fanless nVidia AGP (not PCI-Express, I made a mistake) and DDR RAM...I want that to perform as well as possible, since I don't mind doing any hacks or tweaks.
                      Now, this all leads to me think, that I shouldn't bother with doing this on PC #1, but still try it on PC #2. BEcause if you're saying that the stock driver IS plenty good for general usage, if it ain't broke don't fix it :P
                      So, what do you think? I mean, I'm open to messign around, but I'm not going to bother if there's no point in doing so.
                      • digge
                        • Apr 2006
                        • 296
                        Might be due to your monitor not being detected as it should be. Some monitor report weird or bogus EDID information witch makes the driver confused. You can manually force settings for the monitor in question.
                        Especially TV sets are known to be less accurate in what EDID information they report. It have gotten better over time but it might just be your particular combo.
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          Tried it on both a generic 17" LCD TV/monitor that doesn't even have a model number, and a ViewSonic 15" LCD. neither of those worked.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            media pc--> windows? That's what I had to do with my main rig which doubles as a media pc... but my issues involved getting my digital tv tuner to play well with linux tv viewers... Somethings linux up well, such as my laptop, which has nvidia graphics, some do not. It all depends on the machine, it's purpose, and it's user.
                            sigpic
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              I want it to be a "media PC" without windows.
                              It doesn't have a TV Tuner card. I'm looking to:
                              -Play DVDs, CDs, etc.
                              -Internet Radio (pandora?)
                              -Internet TV
                              All from one software control panel with nice big buttons or something (you know what I mean?). Because It will be on a 17" TV from across the room and I will be using a wireless keyboard/trackpad and it probably won't be super accurate!
                              Of course, I could just use my Lenovo laptop to hook up wirelessly if i get one of those Netgear adapters you hook up to the TV and use Intel Wireless Display...but that's too expensive!
                              • c_hegge
                                • Sep 2009
                                • 5219
                                If his TV tuner works well with Linux (which some do) then I don' t see the need to change to windows. If his only issue is with the graphics being stuck at a low res with the proper driver, then Linux should be fine.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  Ah. It looks like we both posted at the same time. Disregard my last post
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    Ok
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      FWIW, I installed openSUSE (KDE) on an old Socket A machine with an nVidia FX5200 graphics card (which I'm posting from now). I didn't have any issues installing the nVidia drivers.
                                      • piernov
                                        NVidia bumpgate
                                        by piernov
                                        Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                        Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                        May complete this post at a later date with more details.
                                        Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                        03-27-2021, 10:34 AM
                                      • Seanathil
                                        Can't get drivers for Nvidia V100 32gb Installed
                                        by Seanathil
                                        Specs
                                        Ram: corsair vengeance ddr5 16gbx2
                                        CPU: i7-12700KF
                                        Mobo: MSI MPG Z690 Carbon WiFi
                                        GPU: 1660 Super
                                        OS: Windows 11 home
                                        First time installing one of these cards for a client, I did a little research, I couldn't find anything about the card not being compatible with my specs, or other requirements the system doesn't have.
                                        When the card is installed it sometimes shows up in device manager as a 3d accelerator. When I download the drivers from Nvidia they give an error saying no compatible hardware found.
                                        I've checked bios...
                                        08-18-2024, 12:58 PM
                                        NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                                        The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                                        10-02-2024, 08:52 AM
                                        NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                                        The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                                        10-02-2024, 07:51 AM
                                        NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                                        The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mmΒ² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                                        10-01-2024, 01:54 PM
