Microsoft Intellimouse revisions
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    One of the many Microsoft Intellimice i have kicked the bucket.
    It would randomly give usb errors and die... I did find some cracked solder joints on the internal PCB but resoldering had no effect.
    anyway, since I have a few others, I happened to notice that the dead one and my other 3 are not the same.
    Background info: The dead one was from a thrift store. the other 3 are from Purdue university surplus.
    for these pictures, the dead one is on the left and the good one is on the right.
    you can see the good one is yellowed... cosmetically it is kinda ugly, hence why I bought the one that died (It was used with my laptop). form this view, nothing else looks different.
    BUT:
    from the bottom, the labeling is obviously different.
    even the shells are different... note that the dead one has the 2 screws missing... also, there are 2 gray supports that are in different locations, disallowing the swapping of shells.
    but the biggest difference:
    The guts are obviously not the same... the dead one is all on one PCB, while the good one is split into 3. ironically, the switches and usb connector are all in the same spot. also, the good one uses 1 small 'lytic cap, while the dead one uses 2 larger caps.
    the only other ting the mice have in common is they both use the same brand cap... wincap (ironic that that brand was found in a microsoft product?)
    from the looks of the revisions marked, the dead one appears to be a newer build... and also a cheaper build. when resoldering the dead mouse, the single sided PCB seemed very cheap and i was surprised the traces didn't lift off on me. also, I noted that the dead one used clips not screws to hold in the pcb and shell components, unlike the good one.
    my only guess to why they changed a good product was since this model was once a top tier product but became lower tier as laser, 4-way scroll, and cordless mice became the high end products and cost became more important than quality.
    Any comments?
    sigpic
    (Insert witty quote here)
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Microsoft Intellimouse revisions
    funny, I looked at another of my 3 yellowed but working mice and it is actually a single pcb style. the 3rd unit is a 3 pcb unit like the 1st good one.
    very odd...
    sigpic
    • lti
      • May 2011
      • 2547
      The older versions of the Wheel Mouse Optical (the cheapest mouse Microsoft sells) had a single PCB, but the mouse I have uses two boards.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        sounds like they are always changing their designs then...
        sigpic
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16955
          the last MS mouse I had was their wireless optical intellimouse.....took 2 AA batteries. It was laggy as hell, inaccurate, and would go through a pair of batteries a week. Went to logitech's MX1000 wireless laser with a Lithium Ion & recharger, never looked back.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I have one of those somewhere... never used it.
            I have a microsoft wireless desktop 500 set I got for cheap. I used to use it with my imac g5 but it had signal trouble and the mouse's hor. scroll would get tripped whenever I middle clicked. went through 2 AA batteries per device (M/K) per 2 months at the worst.
            I have a logitech set somewhere but the mouse is 3 button... I prefer 5 (I use the side buttons a lot)
            sigpic
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              I use a Microsoft Wireless optical mouse 2.0. Goes through 2 AA batteries a year, is quite accurate and surprisingly low latency.
              • Toasty
                • Jul 2007
                • 4171
                >>It would randomly give usb errors and die... <<
                Likely a bad cable. They really are bulletproof.
                veritas odium parit
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  i see... i will swap the cables and see if it makes a difference.
                  edit- good call. the cable is the issue.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    fixed it!
                    i happened to have a double ended usb cable sitting in my stash. I planned to chop it anyway (for use on two xbox controllers yet to be found/bought), so I took half of it (2.5ft) and soldered it to the pcb:
                    (sorry about the picture quality)
                    it works again... and with a cable less than 1/2 the length and thicker than original, it much better for use with my laptop (the extra cable would often get in caught in things and get in the way). the only fun part was getting the thicker cable to work in the cable channel... it took some force but its in... I might use some super glue to seal the deal since the front is under extra tension with the cable crammed in there.
                    how do you think i did?
                    Thanks Toasty for the hint... the cable looked ok so i never would have guessed.
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      I carved some of the plastic out so there no longer any extra tension. it should be good to go (knock on wood)
                      sigpic
                      • Toasty
                        • Jul 2007
                        • 4171
                        veritas odium parit
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          I don't know if you know this, but if you have some of the earlier version of the intellimouse 1.0, moving it too fast causes the cursor to move in random directions, some later 1.0's and the 1.1+ fixes the problem
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            do you mean the oldskool intellimouse or the one I have in post #1?
                            sigpic
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              probably, some versions do, some don't. Usually if they have no version listed they are 1.0, but I have seen fixed ones that say 1.0
                              move it around really fast, see if the cursor stays up
