python program
  • skystormfarms
    Banned
    • Mar 2011
    • 160
    python program
    i was using a controller off the parallel port running a python program switching the speed of a 5 speed fan when the computer crashes and i look at the psu and i am getting an ac sine-wave along with the dc signal and extra 3v to on all lines how can this happen
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: python program
    could you translate that from gibberish to english?
    I assume you speak more than just gibberish?
    sigpic
    (Insert witty quote here)
    • shadow
      • Feb 2007
      • 732
      Re: python program
      Seems to make sense to me.
      However I am unsure why that would happen.
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Re: python program
        It's not gibberish, it's just a lack of punctuation. Add your own.
        "I was using a controller off the parallel port (running a python program switching the speed of a 5 speed fan), when the computer crashes. I look at the psu, and I am getting an ac sine-wave along with the dc signal and extra 3v to on all lines. How can this happen?"
        Ludicrous gibs!
        • Toasty
          • Jul 2007
          • 4171
          Re: python program
          Assuming a line voltage fan, yes?
          Did the PSU fail and cause the system crash?
          Is the AC present when the PSU is by itself? i.e.- Disconnected from system?
          Did the controller isolation fail somehow? Would that allow AC back to the system?
          Can you diagram the setup?
          veritas odium parit
          • skystormfarms
            Banned
            • Mar 2011
            • 160
            Re: python program
            well toasty the hard drive is toast it was a digital diagram on one 3TB drive only
            • Toasty
              • Jul 2007
              • 4171
              Re: python program
              Ok
              ....and the other questions?
              veritas odium parit
              • skystormfarms
                Banned
                • Mar 2011
                • 160
                Re: python program
                yes a line voltage fan
                yes the PSU fail cause the system crash
                yes there was AC present on the PSU is by itself(Disconnected from system)
                no it use magnetic relays
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  Re: python program
                  Was this power supply plugged in when the pole transformer went kaboom?
                  The power supply you're talking about- does it power just the computer or does it also provide the control power? How are you interfacing the parallel port to the relay coils? Probably one bit per relay coil, via some 2N2222 transistors...
                  On your 5-speed line voltage fan, make sure your program is set to drop one relay before picking up another- don't want more than one speed tap energized at once.
                  Curious about the motor- multi-tapped shaded pole or PSC?
                  -Paul
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                  • skystormfarms
                    Banned
                    • Mar 2011
                    • 160
                    Re: python program
                    yes this power supply was plugged in when the pole transformer went kaboom
                    yes it drops one relay before picking up another
                    yes one bit per relay coil via some 2N2222 transistors
                    and its a multi-tapped shaded pole
                    • reformatt
                      Create MEAnalyzer executable from Github Python Scripts
                      by reformatt
                      Each new release of ME Analyzer only has the scripts but no executable file. It's handy for me to just run the exe in Windows, so came up with the following guide for those that might want it. Didn't see anywhere else how to do it, apologies if it is documented somewhere and I've just missed it.
                      ME Analyzer – create Windows executable from Python script from GitHub
                      1. Install Python 3.xx from https://www.python.org/downloads/ – select to add Python to PATH during installation. Current version is Python V3.11.
                      2. Open an elevated Windows Command Prompt...
                      02-06-2023, 07:33 AM
                    • Nikan.e
                      How to program a specific flash region of a Nations N32G455RE MCU?
                      by Nikan.e
                      Greetings and salutations!
                      I have a device that uses an N32G455RE. Unfortunately, its flash got corrupted. I have a dump of a working chip.
                      How can I program a specific region of the flash or the whole flash without touching the RAM, option registers, etc.?
                      I do not have a J-Link debugger and won't buy one, as I am not rich.
                      I have flashed a Nucleo board with an ST-Link to a J-Link just to find out that the ST-J-Link only supports ST chips.
                      What would be the cheapest and easiest option to program the Nations chip's flash without touching registers etc.?...
                      05-23-2024, 11:51 PM
                    • lapfix
                      ECFinder program
                      by lapfix
                      ECFinder program for searching for firmware of multicontrollers and a number of BIOSes inside any binary files: dumps or unpacked update files.
                      Just Drag your dump in and choose capacity
                      Mod edit: link https://comsystem-tlt.ru/forum/viewtopic.php?t=759
                      05-01-2025, 01:47 AM
                    • Arshad alam4659
                      a1706 smc program
                      by Arshad alam4659
                      I have a1706 820-00923-a, the smc in this board is bad (980 yfe tm4ea231) I have a new smc but the problem is how to program this smc, does anyone know about it pls help
                      01-31-2025, 07:55 AM
                    • pabloroggeri
                      Program IT8886HE with RT809H
                      by pabloroggeri
                      I am trying to program the EC IT8886HE of a Lenovo V310-15ISK with RT809H. (Motherboard DA0LV6MB6F0 REV: E)
                      According to the programmer's software, it must be connected to the SM BUS of the EC (pins 87 and 88 if I'm not mistaken) through the ISP port of the programmer. However, when I want to read or delete the EC it tells me "bot error"
                      Someone has programmed these ECs to help me or tell me what mistake I am making. I leave the photos of the connection diagram, the error that appears and the photo of how I connected the ISP cables
                      Thank you so...
                      01-16-2025, 10:16 AM
