Any Dells not notorious for bad caps?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Any Dells not notorious for bad caps?
    Rubycon, Panasonic, and Nichicon are low quality? Not. It's more along the lines of poor engineering by Dell.... A system that doesn't breathe well tends to cook lytics...
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Originally posted by gerg
      Dell I believe uses the lowest quality components.
      Based on the Intel motherboard, the Rubycon caps, or the Panasonic caps?
      Mann-Made Global Warming.
      - Dr Seuss
      • gerg
        • Nov 2010
        • 278
        Hey you guys are the pro's I will agree to this and retract my previous statement.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          You might be thinking of the older Dells that had the defective Nichicon HM and HN but that wasn't Dells fault and just about every mobo mfr [including Apple] got caught with that one. Nichicon HM & HN are high quality caps but Nichicon screwed up yhose two series from 2001-2004.
          Only other Dell problem is crappy air flow.
          Can blame Dell for that but it's not a parts quality issue, it's a poor case design.
          - Dr Seuss
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
